Arduino Forum making mosquito high frequency to repel
  • Replies 27 replies
  • Subscribers 420 subscribers
  • Views 4693 views
I was hoping to get advice on how to  generates high frequency sound that may repel mosquitoes.
Any ideas on this project ???
    e14 Contributor over 13 years ago in reply to groaker +2
    Dont let someone else's failure hold you back. Give it a shot. you may want to ry different frequencies or multiple frequencies.High, higher, or lower. Give it a try.
  • groaker
    groaker over 13 years ago +1
    A number of studies have demonstrated that high frequency sounds do not repel mosquitos. This bit of folklore probably came about between the presence of bats, of which some species are prodigious eaters…
    michaelkellett over 13 years ago in reply to e14 Contributor +1
    @chinino Why, in the face of evidence to the contrary, are you so convinced that some noise at some high frequency will upset mosqitos. ? Here is a link to supplement Michael Tria's post. http://www.bbc…
  • groaker
    A number of studies have demonstrated that high frequency sounds do not repel mosquitos. This bit of folklore probably came about between the presence of bats, of which some species are prodigious eaters of mosquitos, and the assumption that the high frequency echo location of bats was responsible for the reduced numbers of mosquitos in a area. They were actually concentrated in the bat's stomachs.
    After seeing your question, I decided to do a bit of research on the topic.
    First Source: EurekAlert!
    http://www.eurekalert.org/pub_releases/2007-04/jws-mrt041607.php
    "Mosquito repellents that emit high-pitched sounds don't prevent bites"
    Some key-points from the webpage:
    A Cochrane Systematic Review of the use of electronic mosquito repellents (EMRs) failed to find any evidence that they work.
    To test these claims a team of Cochrane Researchers conducted a systematic review looking for trials conducted with EMRs. They located ten field trials that had been carried out in various parts of the world. None of these trials showed any evidence that EMRs work.
    All ten studies found that there was no difference in the number of mosquitoes found on the bare body parts of the human participants with or without an EMR
    Give it a try.
  • ntewinkel
    ntewinkel over 13 years ago
    I don't know if a piezo speaker/buzzer gets you the right frequencies, but here is an example circuit from Oomlout to make sound:
    http://www.oomlout.com/oom.php/products/ardx/circ-06
    For the high frequencies, maybe keep an eye on nearby dogs and cats when testing - they can hear up to something like 65-85KHz.
    And I guess you can do testing with a few pop-bottle and yeast mosquito traps (one with your repeller, the other without) - that's assuming those traps work image
    Good luck, hope it works out!
    Cheers,
    -Nico
    e14 Contributor over 13 years ago in reply to ntewinkel
    Did not see any specs on FreQ range on oomlout.
    Will need a High Freq speakers but also may have to test with lower freq.  I think some type of noise will repel them.
  • ntewinkel
    ntewinkel over 13 years ago in reply to e14 Contributor
    That Oomlout example is only showing how to hook up a piezo speaker/buzzer and gives a very basic example of how to make some tones, but you can modify the code to get to your desired frequency. Look at their comments for notes, for example:
    * note      frequency      period      timeHigh
    * c     261 Hz     3830      1915
    I'm guessing that changing timeHigh to 19 would give you close to 26,100 Hz, or 26 kHz.
    You'd have to do some math to figure out the required delays to get the desired frequencies (smaller delay = higher frequency), but the rest is pretty much there for you to use.
    Cheers,
    -Nico
    @chinino
    http://www.bbc.co.uk/news/magazine-20669080
    Before you start trying to make any noise try to find some research results that indicate what sort of noise might be effective.
    If you can find any then post a link here I'll be very happy to advise you about how to generate the sounds.
  • groaker
    groaker over 13 years ago in reply to michaelkellett
    There are people who want to believe that the Second Law of Thermodynamics can be violated. That the circle can be squared. That there is a map that need more than four colors. That even though the flu vaccine is a killed vaccine, that it will give them the flu.
    Most of the time such antics keep them busy, and out of harms way. Sometimes, like Andrew Wakefield and the phony MMR-autism link, they do real damage, and kill thousands. Looking for some fx that will frighten away mosquitos is a relatively harmless though fruitless pastime.
    e14 Contributor over 13 years ago in reply to michaelkellett
    @ michaelkellett
    Why, in the face of evidence to the contrary, are you so convinced that you should take someone's failure as written in stone.
    I did not start this question.  But let the man try if he wants to.
    There are people who will help and encourage while there are some that are just such downers.
    So, rick alexanderson  should not even post the question unless you approve.
    Before you start making noise let the man post his question and let others offer advise.
  • groaker
    groaker over 13 years ago in reply to e14 Contributor
    Is it being a downer to reject a thesis that has been repeatedly demonstrated as false. The Cochrane Reviews are a reputalble organization, and they have found 10 studies that demonstrated the failure of high fx sound in chasing mosquitos, and none that supported it.
    When I was very young I tried to make a radio with a shoebox top and some copper wire. My father explained to me that it would never work. Was he being a downer or a realist? When I was old enough, he helped me make a radio. He often explained to me why some of my ideas were more "magical thinking," than reality based. This was in fact useful in later life.
    I spent my career in the physical sciences. Every morning I held a coffee and danish discussion in my office which was attended by anyone who wanted free coffee and danish. We talked about the problems that we were having with our work. One of the most useful things that anyone could do was to say (and back up with sources) that an approach wouldn't work. It would often save months of work that would lead nowhere.
    No where did I suggest that I should be a referee for anyone's work. Stop putting words in my or anyone else's mouths. And you further want to censor me, telling me that I should not comment until everyone else is finished speaking. I was not just making "noise" as you proclaim, but probably know more about mosquitos than most other people here, as my career was in Public Health. And I backed it up with a source (Cochrane Reviews.) The man posted his question, I went on to advise that he was barking up the wrong tree.
    I agree with you, but was not talking to you or putting you down.
    Please read message and you will see it was not directed to you.
    We are all entitled to waste our time as we see fit.
