Arduino Forum Arduino Projects
  • Replies 10 replies
  • Subscribers 419 subscribers
  • Views 1061 views
Arduino Projects
gtrplyer16
gtrplyer16 over 12 years ago
This isn't necessarily a question or comment!!! Just wanted to see what kind of arduino projects people are doing out there. Show your stuff!!
    e14 Contributor over 12 years ago +1
    made a greenhouse controller for environmental monitoring and control of watering system
  • dragonstyne
    dragonstyne over 12 years ago in reply to gtrplyer16 +1
    Greetings Tyler, actually no, I apply power to the Arduino and the lights when I want them to run, I would use a timer otherwise. The GE G35 lights use addressable modules. The Arduino send serial data…
  • gtrplyer16
    gtrplyer16 over 12 years ago in reply to e14 Contributor
    That sounds like a cool project. What all did you use for it?
    e14 Contributor over 12 years ago in reply to gtrplyer16
    used and arduino, DHT11 for temp and humidity sensing, soil resistance sensor, a water pump driven by relay, a fan also driven by relay, and a GSM shield for status reporting.
    it was installed in a greenhouse to automate the watering of the plants
  • dragonstyne
    Greetings Tyler,
    I've used an Arduino Uno to control my outdoor Christmas lights for the last 2 years. The 5 stings contain individually addressable RGB LED units (GE G35)
    -Steve
  • gtrplyer16
    Does the GSM shield only need a SIM card to work? I have an old blackberry that isn't activated anymore. Could I take the SIM card out of that to use in this shield?
  • gtrplyer16
    gtrplyer16 over 12 years ago in reply to dragonstyne
    Steve,
         That's quite interesting. Do you have a photoresistor set to turn the lights on or what is triggering them to turn on?
    mcb1 over 12 years ago in reply to gtrplyer16
    Tyler
    I'm curious why you're asking the question.?
    I know there are many documented projects using Arduino, which would give someone the idea its very versatile, and has many uses.
    There are lots of books (for free) detailing projects that cater for novice to expert.
    The search here is not 100% and you do tend to unable to filter the projects, but even so there is plenty of projects showing in
    http://www.element14.com/community/groups/arduino
  • gtrplyer16
    gtrplyer16 over 12 years ago in reply to mcb1
    mcb1 I am just curious as to what other people have done, to talk about their projects. I have many projects in mind that I am going to be working on. Just wanted to see what kinds of stuff other people were doing, not necessarily for ideas just to get them to talk about it. That is all.
    Tyler
    Okay so care to share or detail the ideas....
    You may find others come out to discuss similar ideas.
  • dragonstyne
    The GE G35 lights use addressable modules. The Arduino send serial data to each individual light, or pixel initially to set the addresses, then commands what color and intensity to illuminate each one. A common ground is required but, the power supplies are the original supplies that came with the lights. There is no way the Arduino could provide the current necessary to run the lights. If you look up Arduino and G35 you will find lots of information on the subject. Also, adafruit.com has addressable LED strings that work well with the Arduino and look great.
    -Steve
