Arduino Forum MQTT client program not showing any results with Arduino
  • Replies 49 replies
  • Subscribers 412 subscribers
  • Views 5399 views
I modified the MQTT example present under MQTT library pubsubclient for Arduino.
My MQTT server address is 192.168.1.6 with port 8081.
To this MQTT server,another MQTT client in my mobile is able to connect.
But this is not working with Arduino.There is no error shown during compilation or during uploading.
Infact,I am not able to see the connection result messages such as "Connected" or "Not connected" which i given in Serial.println() in setup function.
I am resetting Arduino before uploading the program.Please let me know why this is not showing any output....
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
byte server[] = {192, 168, 1, 6 };
//byte ip[]     = { 172, 16, 0, 100 };
void callback(char* topic, byte* payload, unsigned int length) {
  // handle message arrived
EthernetClient ethClient;
PubSubClient client(server, 8081, callback, ethClient);
void setup()
  Ethernet.begin(mac);
  if (client.connect("*")) {
     Serial.begin(9600);
    Serial.println("Connected to MQTT Server");
    client.publish("outTopic","hello world");
   // client.subscribe("inTopic");
  else
   Serial.println("Could not connect to MQTT Server");
void loop()
  //client.loop();
  • neilk
    neilk over 11 years ago in reply to Former Member +3
    generk4 and organtin Hi Radhamani and Giovanni - I had 30 minutes to spare so I copied the program from comment 19 and posted it into the Arduino IDE (I am using 1.6.1), compiled and uploaded it to a genuine…
    Former Member over 11 years ago +3
    Hi Bob, Neil and Clem, I tried LM35 Temperature sensor with MQTT Arduino sketch and it works fine for me I am sooo happy Thanks once again for your wonderful support and help
    Former Member over 11 years ago in reply to bobcroft +2
    Hi bob,Neil,Clem and many others who have helped and guided me in this issue, I have successfully completed MQTT program and Arduino is successfully publishing and subscribing messages Next step,I am going…
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to Former Member
    DHCP does work with the standard Ethernet shield, I have used it on many occasions
    You may want to also check you DHCP server ?
    regards
    Peter
    Hi Peter Oakes,
      Thanks..That and many others can also be added as reasons..
       I have given these lessons learnt from my side since I didnt have issues with DHCP server...
    I didnt press the Ethernet shield properly..Also,I had a faulty Ethernet shield..
    #include <SPI.h>
    // Pins
    // Analog 0 is the input pin
    // Variables
    const int Tempin = 0;
    int value;
    float temp,tempC;
    String pubstring;
    unsigned long time;
    char message_buffer[100];
    // Network Settings
    // MAC address of ethernet shield
    // Look for it on a sticket at the bottom of the shield.
    // Old Arduino Ethernet Shields or clones may not have a dedicated MAC address. Set any hex values here.
    byte MAC_ADDRESS[] = {  0x78, 0x45, 0xC4, 0xAA, 0xE5, 0x6F };
    // IP address of MQTT server
    //byte MQTT_SERVER[] = {0,0,0,0};
    //byte ip[] = {10,107,1,115};
    PubSubClient client;
    void setup()
      // Initilize serial link for debugging
      Serial.begin(9600);
      Ethernet.begin(MAC_ADDRESS);
      Serial.print("Local IP=");
      Serial.println(Ethernet.localIP());
      client  = PubSubClient("0.0.0.0", 1883, callback, ethClient);
    void loop()
      if (!client.connected())
        //client.connect("clientID", "mqtt_username", "mqtt_password");
        client.connect("sfo-arduino");
        client.publish("sfo/arduino/alive", "I'm alive!");
      else{
        client.connect("arduino/temperature");
        Serial.println("here i am connected");
      //tempC = dtostrf(tempF,5,2,message_buffer);
      // Publish sensor reading every X milliseconds
      if (millis() > (time + 5000)) {
        time = millis();
        value = analogRead(Tempin);
        temp = (value/1024.0)*5000;
        tempC = temp/10;
        pubstring = String(tempC);
         pubstring.toCharArray(message_buffer, pubstring.length() + 1);
        client.publish("arduino/temperature",message_buffer);
        //Serial.println("published!");
        //Serial.println(message_buffer);
      // MQTT client loop processing
      client.loop();
    // Handles messages arrived on subscribed topic(s)
    hey i am trying a project on reading lm35 temperature sensor and publish in a mqtt broker using arduino.. I am stuck at subscribe mid1:0 after which it starts pinging..may i know what am i doing wrong here??
    Thanks in advance..kindly reply asap
  • clem57
    clem57 over 10 years ago in reply to Former Member
    Did you set the server address?
    Clem
    Robert Peter Oakes over 10 years ago in reply to Former Member
    As per what clem57 said, the server address is not set for starters "client  = PubSubClient("0.0.0.0", 1883, callback, ethClient);" does not contain a valid server address even if it is a local MQTT server
    second error is
    else
    if the first connect failed, what makes you think the else clause is going to work ???
    hey thanks for ur suggestions and i have updated my code like this..and i found that my arduino and mqtt is still not getting connected returning rc as -2..here is the code..any idea what is the problem??
    float temp;
    int tempPin = 0;
    #include <SPI.h>
    byte mac[] = { 0x78, 0x45, 0xC4, 0xAA, 0xE5, 0x6F };
    IPAddress ip(192, 168, 1, 108);
    IPAddress server(192, 168, 1, 100);
    char buff[3];
    temp = analogRead(tempPin);
      temp = temp * 0.48828125;
    Serial.print("TEMPRATURE");
      Serial.print(temp);
      Serial.print("*C");
      Serial.println();
      dtostrf(temp,4,3,buff);
    PubSubClient client(ethClient);
    void reconnect() {
    // Loop until we're reconnected
    while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("arduinoClient"))
    { Serial.println("connected");
    // Once connected, publish an announcement...
    client.publish("/home/temperature","alive");
    // ... and resubscribe
    client.subscribe("/home/temperature"); }
    else { Serial.print("failed, rc=");
    Serial.print(client.state());
    Serial.println(" try again in 5 seconds");
    // Wait 5 seconds before retrying
    delay(5000); } } }
    void setup()
    { Serial.begin(9600);
    client.setServer(server, 1883);
    client.setCallback(callback);
    Ethernet.begin(mac, ip);
    // Allow the hardware to sort itself out
    delay(1500); }
    void loop()
    { if (!client.connected())
    { reconnect();
    } client.loop();
    hey guys mqtt_basic program itself is failing for me...and arduino mqtt function almost always fails..any ideas??
    kindly reply asap
    arduino mqtt connection*
  • clem57
    How to Ask Questions using the Create Discussion tool
