    • Avnet Boards Community
Arduino Forum What are some good first projects
  • Subscribers 394 subscribers
  • Views 427 views
tdguy
tdguy over 10 years ago
What I'm looking for are some great first projects and maybe some more advance projects for a beginner who is learning outside of the traditional learning medium.  Just a good beginnings for anybody that is new and needs help in a good direction just to get the experience would be nice.
  • 4ringfan
    4ringfan over 10 years ago in reply to tdguy +3
    This might be a good place to get some project ideas for the Arduino. http://tronixstuff.com/tutorials/ I repair dental equipment for a living and I work on pneumatically controlled systems. Wouldn't be…
    dougw over 10 years ago in reply to tdguy +1
    Maybe you could try making a reaction timer..... where an LED starts a millisecond counter and a switch (that you hit) stops the counter. Try displaying the result on some seven segment LED displays or…
    dougw over 10 years ago +1
    Here is another arduino + sensors idea: Tis The Season For Arduino
  • clem57
    clem57 over 10 years ago
    Wow that is a big area. How about you giving a few specifics like
    • Your areas of expertise/interests
    • Your goals or aspirations
    • What is this non traditional learning medium? Is it do and learn(which I prefer)
    • What hardware do you have or are you asking? a suggested budget maybe.
    Clem
  • tdguy
    tdguy over 10 years ago in reply to clem57
    That is a good point.
    Some of the areas I'm in is micro-controllers (arduino), robotics, and power systems.
    A couple of goals I'm interested in are
    • Regulated e-cigarette mods
    • power control modules
    • flow control modules (controlling liquids like water, oil, ect)
    As to non traditional, I've been indoctrinated until recently to think that the best way to go through school is to go into college which is what I'm classifying as "Traditional" in my message.
    Equipment I have
    • Soldering station
    • Standard hand tools
    • Networking crimping tools
    As to a budget, for the projects I'm looking at keeping each project at or below about $20 in total of parts.  I have found a few that are less than $5 around.
    Because I'm just getting into this, I may be saying things that I think are right but are way off so any help there would be nice too.
    Again, thanks for the help.
  • 4ringfan
    I repair dental equipment for a living and I work on pneumatically controlled systems.  Wouldn't be too difficult to combine a small air compressor and some solenoids all controlled by an arduino to do all kinds of cool things.  You could use a paddle pump and pinch valves.  I have a bunch of ideas revolving around p and f, but I'm saving them for a future idea post i'm working on.
    Make an automated plant waterer.
    Maybe you could try making a reaction timer..... where an LED starts a millisecond counter and a switch (that you hit) stops the counter. Try displaying the result on some seven segment LED displays or even an LCD.
    There are many ways to tweak and improve such a system - make bigger displays, add sound effects, record best times, etc. You can substitute an audio "beep" start signal and determine if your audio response is faster than your visual response or if loudness or brightness of trigger helps performance. You can add multiple stop switches that must be selected based on which trigger is initiated to determine how decisions slow down response.
    It is always fun to test your reactions - everybody thinks they are fast. Then try it again after a couple of beers....
    There are lots of good things, often explained, at...
    Arduino Playground - HomePage
    You'll want to watch out for things that need too many, too expensive "add ons", or just components. Also, a novice can run into trouble when things clash that work fine in isolation... but that's just a portion of the learning curve to be dealt with... sometime.
    There are many online courses which are built around Things You Can Do. Indeed, it is pretty hard to write a course that is NOT example led. Well... one that I would want to read!
    The advantage of a "course" is that the author has, we hope, tried to go from step to step, introducing new bits of "the Arduino will do this if you do that" in a logical and constructive sequence.
    If you'll forgive me grinding my own axe, I've tried to do just that with...
    Course for Arduino Programming: table of contents- (FA1main.htm)
    It probably isn't the best one out there... but I did teach for 20 years, 12 of them "officially" teaching computing, and sneaking computers into science lessons for some of the other!
    I hope other people will suggest others to you.
    I would also commend the Arduino Forum - Index as a place to go. Look at the things other people are doing. Before long, you'll see things that make you say "I want to try THAT!..."
