Arduino Forum Shift registers. SPI or daisychain ?
  • Subscribers 403 subscribers
  • Views 632 views
  • spi
  • shift_register
  • 74hc595
Hi everybody. Please forgive me if that question have been asked before (i didn't find anything on this forum though).
I am planning to use shift registers (74HC595) to drive solenoids and I am wondering what is the difference between daisychaining the 595s ans using SPI
At same time I am wondering what is the point of using SPI since on the schematics I saw over the internet requires to link the 595s chips via their Serial input pins (like when daisychaining).
Would it be possible to use each 595s as a Slave without linking them each other (probably not since they don't have a chip select pin).
Any help / advice will be appreciated.
Have a good day/night.
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +1
    you could linkeach of those chips in series or have them seperate but that will require alot more pins of course A better option in my opinopn is the CD74HC4094 which can be directly connecte to a SPI…
    Former Member over 10 years ago +1
    Thank you Peter and Enrico for your answers. I will have a look at theses ICs your mention. although I think I will go with 74hc595 daisychained since I have dozens of them already at hand.
    0 Robert Peter Oakes over 10 years ago
    A better option in my opinopn is the CD74HC4094 which can be directly connecte to a SPI bus and if you want each can have the strobe line to a different I/O or together if the chips are put in series.
    the other one which provides more flexability is the MCP23S17 which gives you 16 i/o lines all in one SPI attached chip
    0 balearicdynamics over 10 years ago
    Hello Cédric,
    Peter is correct, with 74HC595 you need more PIns if you don't daisy-chain them together, else you should adopt a different kind of IC (I prefer the CD74HC4094). About daisy-chaining I have done a simple project, published some time ago on electroschematics.com Take a look if it can be what you need.
    Arduino Daisy Chain Shift Register with 74HC595 - Part 1
    Enrico
    After reading the specs of the MCP23S17 looks like an interesting choice.
