    • Avnet Boards Community
Arduino Forum buttons
  • Replies 15 replies
  • Answers 5 answers
  • Subscribers 395 subscribers
  • Views 1146 views
buttons
Former Member over 9 years ago
I want to us 7 buttons with my arduino uno which will send out different values. For example if i press one button i will get the value of 10, if i press a different button i will get 20, if i press another i will get 30 etc. I haven't found a way to separate the results sent to the serial port.
  • Nate1616
    Nate1616 over 9 years ago +2 suggested
    Simon- What does you current code look like? It seems like you are printing all the button states in one line. Is this correct? What you could do is have a line that checks if the button state is high…
  • mrchunckuee
    mrchunckuee over 9 years ago +2 suggested
    Simon in the function setup not defined buttons as input. const int bt = 2; const int bt1 = 4; int btState = 1; int lastState = 1; void setup(){ pinMode(bt, INPUT); pinMode(bt1, INPUT); Serial.begin(9600…
  • Nate1616
    Nate1616 over 9 years ago in reply to Former Member +2
    Pedro beat me to it.
  • clem57
    0 clem57 over 9 years ago in reply to Former Member
    int myChar[] = {"261", "293", "329", "349", "392", "440", "493" };
    int butArray[] = {2, 3, 4, 5, 6, 7, 8};
    int count = 0;
    int timer = 50;
    void setup(){
    Serial.begin(9600);
       while (!Serial);
    for (count=0;count<6;count++) {
      pinMode(butArray[count], INPUT);
    void loop() {
      for (count=0;count<7;count++) {
    /* read value of buton based on butArray see Arduino - Debounce */
      If butArray[count] = 'HIGH' {
         Serial.print(myChar[count]);
      delay(timer);
    0 Former Member over 9 years ago in reply to clem57
    Thanks for the code Clem but it says that there is an invalid conversion from 'const char' to 'int'
  • clem57
    Take out the " marks on the first line. You need to complete the comment into code reading Arduino - Debounce
    for the details how.
    do you have an example of that i don't understand what you mean
    0 Former Member over 9 years ago in reply to Former Member
    let me guess, you are making a musical keyboard, and 261 is the frequency for middle C.
