Arduino Forum buttons
  • Replies 15 replies
  • Answers 5 answers
  • Subscribers 405 subscribers
  • Views 1340 views
buttons
Former Member over 9 years ago
I want to us 7 buttons with my arduino uno which will send out different values. For example if i press one button i will get the value of 10, if i press a different button i will get 20, if i press another i will get 30 etc. I haven't found a way to separate the results sent to the serial port.
  • Nate1616
    Nate1616 over 9 years ago +2 suggested
    Simon- What does you current code look like? It seems like you are printing all the button states in one line. Is this correct? What you could do is have a line that checks if the button state is high…
  • mrchunckuee
    mrchunckuee over 9 years ago +2 suggested
    Simon in the function setup not defined buttons as input. const int bt = 2; const int bt1 = 4; int btState = 1; int lastState = 1; void setup(){ pinMode(bt, INPUT); pinMode(bt1, INPUT); Serial.begin(9600…
  • Nate1616
    Nate1616 over 9 years ago in reply to Former Member +2
    Pedro beat me to it.
  • Nate1616
    0 Nate1616 over 9 years ago
    Simon-
    What does you current code look like?  It seems like you are printing all the button states in one line.  Is this correct?  What you could do is have a line that checks if the button state is high then print that line.
    Nate
    0 Former Member over 9 years ago in reply to Nate1616
    Thanks for the help Nate,
    my code looks like this, it sends out 440 or 392 but its not coming from the result of different button presses
    const int bt = 2;
    const int bt1 = 4;
    int btState = 1;
    int lastState = 1;
    void setup()
      Serial.begin(9600);
    void loop()
      btState = digitalRead(bt);
      if (btState != lastState)
        if (btState == HIGH)
        else
          Serial.println(440);
        delay(30);
        lastState = btState;
      btState = digitalRead(bt1);
        else
          Serial.println(392);
        delay(30);
  • mrchunckuee
    0 mrchunckuee over 9 years ago
    const int bt = 2;
    const int bt1 = 4;
    int btState = 1;
    int lastState = 1;
    void setup(){
      pinMode(bt, INPUT);
      Serial.begin(9600);
    void loop()
        delay(30);
        delay(30);
  • gihu
    0 gihu over 9 years ago in reply to Former Member
    It seems it is missing the pin configuration in the setup.
    void setup()
      pinMode(bt,INPUT);
      pinMode(bt1,INPUT);
      Serial.begin(9600);
    Hope that helps,
    Miguel
  • Nate1616
    0 Nate1616 over 9 years ago in reply to Former Member
  • gihu
    0 gihu over 9 years ago in reply to gihu
    PedroSanchez was faster...
    0 Former Member over 9 years ago in reply to mrchunckuee
    HI Pedro this helped but when I press the button connected to pin 2 I get 440 out of it and sometimes 392 it does not always give me 440 only out. it is the same with the second button
  • Nate1616
    Try this link to solve your problem Simon.  https://www.arduino.cc/en/Tutorial/Debounce
  • clem57
    0 clem57 over 9 years ago
    What is the endgame here? If we knew that, there are techniques of multiplexing the buttons.
    Clem
    0 Former Member over 9 years ago in reply to clem57
    The end result i want is to have 7 buttons connected to my arduino.
    If button 1 is pressed it will send the value 261 to the serial port once.
    If button 2 is pressed it will send the value 293 to the serial port once.
    If button 3 is pressed it will send the value 329 to the serial port once.
    If button 4 is pressed it will send the value 349 to the serial port once.
    If button 5 is pressed it will send the value 392 to the serial port once.
    If button 6 is pressed it will send the value 440 to the serial port once.
    If button 7 is pressed it will send the value 493 to the serial port once.
    Hope that makes sense
