Arduino Forum Arduino connection help
  • Replies 38 replies
  • Answers 11 answers
  • Subscribers 420 subscribers
  • Views 4468 views
alexparker2002
alexparker2002 over 9 years ago
I have made an integrated arduino monitoring system with 3 sensors....
I have used leds to show their values
But i want to add a lcd to it and an ethernet shield to it..... Is it possible?
Let me tell you that I am a beginner.....
Ive attached the schematics please modify it and tell me...... Please!!!!!!
imageFA5RM0AHX1W2JT3.pdf
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago +2 suggested
    You should be able to do it but You will need to use a WS5100 type ethernet shield as it will offload some of the software to the hardware. It will plug into the Arduino UNO, it uses pins 10,11,12,13 you…
  • beacon_dave
    beacon_dave over 9 years ago in reply to beacon_dave +2 suggested
    Also perhaps be aware that the power rails on some breadboards are not continuous but instead are interrupted half way along. You may find that you need to place a jumper on your ground rail between block…
    mcb1 over 9 years ago in reply to alexparker2002 +2 suggested
    alexparker2002 Part of learning is the LEARNING part. Having someone do all the work for you is not learning, but copying . I suggest you explore the examples that are provided in the Arduino IDE. There…
  • clem57
    0 clem57 over 9 years ago in reply to alexparker2002
    Sorry this forum is for helping people and not for "easy answers" where few exists.The previous people have given great guidance, but it is up to you to assimilate and implement as you see fit. Everyone should want to learn first before getting the eureka moment of discovery. I do wish you success on your project. But the true joy is the journey not the endpoint.
  • beacon_dave
    0 beacon_dave over 9 years ago in reply to alexparker2002
    The author of the original Instructables project Plant Health Monitor appears to have updated it here:
    DIY Smart Plant pot - 5
    0 mcb1 over 9 years ago in reply to alexparker2002
    alexparker2002
    Having someone do all the work for you is not learning, but copying.
    There are examples for using the Ethernet when the Ethernet Library is installed.
    There are plenty of examples for both the LCD and I2C connected LCD.
    Robert Peter Oakes has already given some advice on using an I2C LCD to save you the pin conflict.
    You still have software to write, so understanding the basics will help you to write this, or modify some existing code.
    You could also search the forum for the design challenges where a similar concept was done.
    The was a lot of discussion regarding monitoring soil moisture and some of the issues found.
    It looks like a good project as a standalone, which could have the ethernet connected later.
    mark
    0 Robert Peter Oakes over 9 years ago in reply to mcb1
    As mcb1 has said, I provided you answers and a place to move forward with, you need to do some work here, simple google effort will easily show you schematics on wiring an I2C LCD Display and how to plug in an Arduino Ethernet Shield to the UNO. I have told you the pins they use so all that is left is for you to discover with a little effort your software answers and to tweak your fritzing diagram. You did create that one right ?, so you have a handle on how to edit and update the schematic.
    Once you're done, bring it to use and we can help you refine it if needed. Once you have assembled your software by trying each of the examples for the various modules you want to include and then combining them, post it here and we can help you move forward too.
    As many have already said, we will all happily help, we just won't do it for you... sorry, there is just not enough hours in the day if we opened up that flood gate to everyone that asked us to do it for them
    Peter
  • alexparker2002
    0 alexparker2002 over 9 years ago in reply to Robert Peter Oakes
    Thanks Peter
  • beacon_dave
    You may want to take a look at this tutorial as it takes you step-by-step through how to control a LED from a photo resistor for measuring ambient light and also later from a thermistor for measuring temperature. It shows the schematic of the circuit, the Arduino code and it in operation.
    Tutorial 04 for Arduino: Analog Inputs
    However it sounds like you would benefit greatly from starting at tutorial 1 and working your way through 2 and 3 until you reach tutorial 4
    Jeremy Blum Arduino Tutorials
  • beacon_dave
    0 beacon_dave over 9 years ago in reply to beacon_dave
    The 'Arduino Cookbook' by Michael Margolis would be another good reference to learn from if you can get hold of a copy:
    Arduino Cookbook, 2nd Edition - O'Reilly Media
    It covers connecting up and programming of photo resistors, temperature sensors, LCD displays and Ethernet shields, plus a whole lot more.
  • beacon_dave
    Another reference which may be of interest - this one should help cover potential dividers and the moisture sensor aspects.
    https://www.rs-online.com/designspark/what-you-could-do-in-an-hour-teach-basic-circuit-theory-so-it-will-be-remembered
  • dwinhold
    0 dwinhold over 9 years ago
    Like everyone is saying, we are here to guide and help everyone, we were all beginners at one time. There are lots of great books out there as well as information on the internet, you said you are a beginner, start with something easier (a comfortable level for you) and work your way up. I find myself getting in over my head with the complexity of my project, what I do is set them aside until I have built up the knowledge to continue it. Some have been sitting for years but I haven't given up on them. As you see with the many responses and helpful information we are here to guide you in the right direction. It is more gratifying to complete the project with little help then to have it done for you. Start with the basics, not the top.
    Dale
    0 mcb1 over 9 years ago in reply to beacon_dave
    I've posted before on how to get an electronic copy, without using your credit card.
