Arduino Forum Arduino connection help
  • Replies 38 replies
  • Answers 11 answers
  • Subscribers 420 subscribers
  • Views 4493 views
alexparker2002
alexparker2002 over 9 years ago
I have made an integrated arduino monitoring system with 3 sensors....
I have used leds to show their values
But i want to add a lcd to it and an ethernet shield to it..... Is it possible?
Let me tell you that I am a beginner.....
Ive attached the schematics please modify it and tell me...... Please!!!!!!
imageFA5RM0AHX1W2JT3.pdf
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago +2 suggested
    You should be able to do it but You will need to use a WS5100 type ethernet shield as it will offload some of the software to the hardware. It will plug into the Arduino UNO, it uses pins 10,11,12,13 you…
  • beacon_dave
    beacon_dave over 9 years ago in reply to beacon_dave +2 suggested
    Also perhaps be aware that the power rails on some breadboards are not continuous but instead are interrupted half way along. You may find that you need to place a jumper on your ground rail between block…
    mcb1 over 9 years ago in reply to alexparker2002 +2 suggested
    alexparker2002 Part of learning is the LEARNING part. Having someone do all the work for you is not learning, but copying . I suggest you explore the examples that are provided in the Arduino IDE. There…
  • beacon_dave
    0 beacon_dave over 9 years ago in reply to alexparker2002
    Why do you think it will be easier for your project ?
    There are advantages and disadvantages either way.
  • alexparker2002
    0 alexparker2002 over 9 years ago in reply to beacon_dave
    As  i am from India the Grove base shield cost around $49....which is about 3500 rupees here.... And i just can't invest so much in just a single piece....... Any suggestions what to do?
    0 mcb1 over 9 years ago in reply to alexparker2002
    Grove shields and the sensors simply provide a convienient method of connection.
    I use these for prototyping or checking something before building it.
    https://www.itead.cc/prototyping/electronic-brick.html
    and use one of their arduino boards to connect to
    https://www.itead.cc/development-platform/arduino/iteaduino-uno.html
    They are quite a bit cheaper, but again are a convienient connection method.
  • beacon_dave
    You could save some rupees by not using a shield at all and just connect to the Arduino directly. As has been mentioned before a lot of this is convenience versus cost.
    There is the Adafruit proto shield which is a bit cheaper and has the advantage of allowing you to start off with using a mini breadboard to prototype your design, but also allow you to later move from the breadboard to soldering directly onto the prototype shield for a more permanent design and then allow you to stack an Ethernet shield on top.
    https://cdn-shop.adafruit.com/1200x900/2077-08.jpg
    There is also breadboard, protoboard, stripboard, for prototyping and you could etch your own PCB out of copper clad board.
    It also partly depends on what you are planning on doing with this project longer term and whether or not you plan to reuse any components / materials for future projects.
  • alexparker2002
    Can u please describe a bit elaborately of connecting the adafruit protoboard to uno and the sensors, wifi shield, and lcd....
  • beacon_dave
    The Adafruit proto shield plugs into the uno just like any other shield
    https://cdn-shop.adafruit.com/970x728/2077-02.jpg
    It can accommodate a mini breadboard for early prototyping
    https://cdn-shop.adafruit.com/970x728/2077-08.jpg
    You can solder components directly into it for a more permanent prototype
    https://cdn-shop.adafruit.com/970x728/2077-09.jpg
    You can stack another shield on top of it e.g. Ethernet shield
    https://cdn-shop.adafruit.com/970x728/2077-06.jpg
    Once again, the proto shield mainly adds convenience to a prototype, and allows you to unplug a prototype circuit from the uno in one go if you want that sort of functionality.
    Wires from sensors / displays either need to be connected to either the header pins, the breadboard or soldered to the proto board copper pads.
    If you watch the Jeremy Blum Arduino Tutorials  they will show you how to connect sensors and LCD displays to an uno / breadboard.
  • alexparker2002
    Thanks dave...... But is their any particular way of connecting to a protoboard?
  • beacon_dave
    Usually by soldering. Either solder the wires directly to the copper pads or alternatively solder a connector to the board to allow you to plug the sensors, LCD in.
    Perhaps take a look at this episode of the Ben Heck Show for a tutorial on how to use a proto board.
    Episode 226: Ben Heck’s Super Soldered Atari 2600 Episode
    If that is too advanced then this episode on soldering may help
    Episode 161: Ben Heck Teaches Alyson How to Solder Episode
    and this episode on reading a schematic and implementing it on breadboard may help
    Episode 86: Watch Ben Heck’s Schematics Episode
    [edit ...and this one for connectors
    Episode 191: Ben Heck's Essentials Series 1 - Connectors Episode  ]
