Arduino Forum Programing issue
  • Replies 37 replies
  • Answers 3 answers
  • Subscribers 420 subscribers
  • Views 4894 views
  • programing
Programing issue
dirtdiver
dirtdiver over 14 years ago
so I have a dc motor and a servo each controlled with a different potentiometer.First I made two separate codes and all works fine, but when I combine the two codes the servo starts getting readings from both pots.Here are the working codes
int motorPin = 9;
int potpin = 0;
int val;
void setup()
  pinMode(potpin,INPUT);
pinMode(motorPin, OUTPUT);
void loop()
  val = analogRead(potpin);
  val = map(val, 0, 1023, 0, 255);
analogWrite(motorPin, val);
  delay(15);
AND
#include <Servo.h>
Servo myservo;
int potpin = 5;
int val;
void setup()
  myservo.attach(3);
void loop()
  if (val<300){
  myservo.write(67);
  }else if (val<600){
  myservo.write(89);
  } else {
    myservo.write(109);
delay(15);
Heres the combined code that doesnt work.If you see whats wrong please reply, couse I cant find the mistake here.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int motorPin = 9;
int potpin1 = 5;  // GEARS
int potpin = 0;  // SPEED
int val;    // variable to read the value from the analog pin
void setup()
  pinMode(potpin1,INPUT);                //GEARS
  pinMode(potpin,INPUT);                 //SPEED
myservo.attach(3);  // attaches the servo on pin 9 to the servo object
void loop()
  val = analogRead(potpin);           //SPEED
  val= map(val, 0, 1023, 0, 255);
  delay(15);
  val = analogRead(potpin1);            //   GEARS
  if (val<300){
  myservo.write(130);
  }else if (val<600){
  myservo.write(110);
  } else {
    myservo.write(90);
delay(15);
int motorPin = 9;
int potpin = 0;  // analog pin used to connect the potentiometer
void setup()
void loop()
  delay(15);
ALSO HERES A VIDEO SHOWING THE APLICATION OF THE FIRST TWO CODES
http://www.youtube.com/watch?v=MrHqeFmT6DU
  • dmaruska
    dmaruska over 14 years ago in reply to dirtdiver +1
    Most welcome...
  • dmaruska
    0 dmaruska over 14 years ago in reply to dirtdiver
    Hi,  Can I ask, what is the end result of this project.  What is the servo doing and what is the motor doing? Just trying to understand the end result?  Thanks...
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to e14 Contributor
    Thanks I will give it a try and report back to you image
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to dmaruska
    Its supposed to be a mini car throttle control - reverse and forward
  • dmaruska
    What is the Servo for?
  • dirtdiver
    changing the motor's rotation direction
  • dmaruska
    This seems a bit complicated, Cool looking but just not practical.  Have you though about this?
  • dirtdiver
    what exactly is 1-8 ,
  • dmaruska
    This is a generic Relay.  If you use a relay, read the datasheet and see which is the COIL on the relay, same with the contact leads.  Some relays are polorized and + and - must be on specific pins.  This relay is a DPDT type, if used make sure that a BREAK before MAKE type is used.
  • dirtdiver
    How many pins do I need to controll this relay
  • dirtdiver
    nope, that did't help, the problem still exists.But it must be a software issue ,I dont think its a power issue couse I have the motor running on 9 volts (arduino controls only the transistor) and the servo is powerd by a sepparate 5v line
