Arduino Forum Programing issue
  • Replies 37 replies
  • Answers 3 answers
  • Subscribers 420 subscribers
  • Views 4863 views
  • programing
Programing issue
dirtdiver
dirtdiver over 14 years ago
so I have a dc motor and a servo each controlled with a different potentiometer.First I made two separate codes and all works fine, but when I combine the two codes the servo starts getting readings from both pots.Here are the working codes
int motorPin = 9;
int potpin = 0;
int val;
void setup()
  pinMode(potpin,INPUT);
pinMode(motorPin, OUTPUT);
void loop()
  val = analogRead(potpin);
  val = map(val, 0, 1023, 0, 255);
analogWrite(motorPin, val);
  delay(15);
AND
#include <Servo.h>
Servo myservo;
int potpin = 5;
int val;
void setup()
  myservo.attach(3);
void loop()
  if (val<300){
  myservo.write(67);
  }else if (val<600){
  myservo.write(89);
  } else {
    myservo.write(109);
delay(15);
Heres the combined code that doesnt work.If you see whats wrong please reply, couse I cant find the mistake here.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int motorPin = 9;
int potpin1 = 5;  // GEARS
int potpin = 0;  // SPEED
int val;    // variable to read the value from the analog pin
void setup()
  pinMode(potpin1,INPUT);                //GEARS
  pinMode(potpin,INPUT);                 //SPEED
myservo.attach(3);  // attaches the servo on pin 9 to the servo object
void loop()
  val = analogRead(potpin);           //SPEED
  val= map(val, 0, 1023, 0, 255);
  delay(15);
  val = analogRead(potpin1);            //   GEARS
  if (val<300){
  myservo.write(130);
  }else if (val<600){
  myservo.write(110);
  } else {
    myservo.write(90);
delay(15);
int motorPin = 9;
int potpin = 0;  // analog pin used to connect the potentiometer
void setup()
void loop()
  delay(15);
ALSO HERES A VIDEO SHOWING THE APLICATION OF THE FIRST TWO CODES
http://www.youtube.com/watch?v=MrHqeFmT6DU
  • dmaruska
    dmaruska over 14 years ago in reply to dirtdiver +1
    Most welcome...
    0 DAB over 14 years ago
    Have you tried declaring a second variable for the servo?  I don't know if the compiler has scope issues with variables, plus, it is always a good idea to separate your variables and make them unique to each task.  I once made that mistake and it created a "Gremlin" in my code that took almost a year to find.
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to DAB
    I tried it with val and val1 if thats what you mean.
    int val;
    int val1;
    val1 = analogRead(potpin1);
    ...and so on, but it didnt work (the same issue)
  • cookieglitch
    0 cookieglitch over 14 years ago
    Have you tried writing the pot values to the serial line to see what they are reading when you change them?
    Does the code work when the outputs are connected to LEDs rather than the servo and motor? If it works (with a couple of minor software changes for the servo), it may be that the motors are trying to draw too much power. Hard to say however  with schematics etc.
  • MDeGrauw
    0 MDeGrauw over 14 years ago
    You say you have a dc motor and a servo.
    But when i check your code as far as i see you connector then both to pin 9. This results in your problem connect your dc motor for example to pin 10 and change to program for the dc motor part for it.
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to cookieglitch
    Yes, both post work fine.
    Heres how its all hooked up
  • dirtdiver
    0 dirtdiver over 14 years ago in reply to MDeGrauw
    What do you mean
    int motorPin = 9;
    myservo.attach(3);
    dont look at // attaches the servo on pin 9 to the servo object
  • dirtdiver
    I also tried that one (with two vars , but it still doesnt work)
    #include <Servo.h>
    Servo myservo;
    int motorPin = 9;
    int val;
    int val2;
    void setup()
    myservo.attach(3);
    void loop()
      delay(15);
      val2 = analogRead(potpin1);            //   GEARS
      if (val2<300){
      myservo.write(130);
      }else if (val2<600){
      myservo.write(110);
      } else {
        myservo.write(90);
    delay(15);
    I just cant see whats wrong with it..
  • dirtdiver
    "with a couple of minor software changes for the servo"
    like what , couse I want to try it, nothing else seems to work
  • cookieglitch
    0 cookieglitch over 14 years ago in reply to dirtdiver
    To test it using LEDs rather than the motors,, you'll need to change the servo code so it is doing it with analogWrite much like you have with the other motor. Just comment out the servo code and replace it so you know what has changed. If you can get the LED to dim etc as you change it, you may know whether it is a power issue or a code issue.
    0 e14 Contributor over 14 years ago in reply to dirtdiver
    In your combined code, add
    void loop() {
    val = analogRead(potPin);     //Pot Pin
    Serial.print("Value Read = ");
    Serial.println(val);
    Serial.print("Value Mapped = ");
    //You will know what you are Reading and What you are writing to your motorPin. It may be the sorce of your problem.
    //You will need something like this: val = map(readVal, 0, 1023, 0, 255);
    //I faced the same problem and made it to work just by making these changes...
    //Also, in your setup() function...Add the following line
    Serial.begin(9600); // for seeing the values on your serial monitor
