Arduino Forum Where should I go to learn about steppers motors?
  • Replies 9 replies
  • Answers 2 answers
  • Subscribers 402 subscribers
  • Views 778 views
  • information
  • motors
  • learning
lokkytron
lokkytron over 10 years ago
Well, I am trying to make a choice about dc motor with variable speed or step by step motor with microsteps driver to control the mechanism that I explained here
What i need to know is: Is there any resource in this site or another where i can start to learn about dc motors?
I am making random readings after many searches in google... but i don't know enough about these motors to get usefull information.
Thank you.
    shabaz over 10 years ago +4 suggested
    You could read a bit about a few different types of motors here: http://www.element14.com/community/community/applications/industrial-automation/blog/2015/02/14/motors--pm-dc-bldc-servo-stepper-moving…
  • neilk
    neilk over 10 years ago +2 suggested
    Hi lokkytron you could also have a quick look here: http://www.element14.com/community/people/neilk/blog/2015/01/24/arduino-controlling-stepper-motor-28byj-48-with-accelstepper-library and perhaps here…
  • peterjcs23
    peterjcs23 over 10 years ago +1
    Sounds like you need to control speed and position, in which case the stepper motor is a straightforward solution if you are not looking for very high speed or very high torque. If you use a dc motor you…
    0 shabaz over 10 years ago
    You could read a bit about a few different types of motors here: http://www.element14.com/community/community/applications/industrial-automation/blog/2015/02/14/motors--pm-dc-bldc-servo-stepper-moving-coil
    Brushed DC motors can be controlled with an Arduino as shown here: http://www.element14.com/community/groups/internet-of-things/blog/2015/02/11/getting-started-with-the-infineon-dc-motor-control-board
    Stepper motor control with Arduino can be found here: https://learn.adafruit.com/adafruit-arduino-lesson-16-stepper-motors/overview
  • lokkytron
    0 lokkytron over 10 years ago in reply to shabaz
    Thank you very much shabaz
  • neilk
    0 neilk over 10 years ago
    and perhaps here:
    http://www.element14.com/community/people/neilk/blog/2015/02/19/test
    Good luck
    Neil
  • lokkytron
    0 lokkytron over 10 years ago in reply to neilk
    Thank you Neil Kenyon
  • peterjcs23
    0 peterjcs23 over 10 years ago
    Sounds like you need to control speed and position, in which case the stepper motor is a straightforward solution if you are not looking for very high speed or very high torque. If you use a dc motor you will have to add a speed and position feedback device such as an encoder and a more complex controller that a stepper controller. Peter
  • peterjcs23
    ...also there are a lot of useful application notes on the Texas Inst website as they make the chips you need for many types of drives, you could start at Application - Motor Drive & Control - TI.com...Peter
  • lokkytron
    0 lokkytron over 10 years ago in reply to peterjcs23
    Thank you peterjcs23
    And you are right, I need a very slow movement and a high control of position.
    The torque is a trouble, I haven't yet decided how the mechanism will be mounted. In addition I need to mount a small prototype to practice and learn so much as i can, but then I will have to mount the same mechanism but a very heavy version (10-12 kgr)
    I have some ideas but not ordered yet in my head... so I was asking, trying to find the best way to accomplish, or at least began with I want to make.
  • peterjcs23
    0 peterjcs23 over 10 years ago in reply to lokkytron
    good luck with your design deliberations. Slow speed and high torque a good combination as you can choose a smallish motor and add a high ratio gearbox. You need to check the motor speed vs torque characteristic to make sure you get the torque at the speed you want. Torque is multiplied by the gear ratio and speed divided. It still sounds to me like a good stepper motor application as long as you have enough torque and do not slip steps.
  • lokkytron
    Those are the points I have in mind. Thank you peterjcs23
