Arduino Forum pls how do i go about communicating with 2 arduinos with the use of the tx/rx pin.
  • Replies 17 replies
  • Subscribers 403 subscribers
  • Views 1745 views
i have codes for pulse sensor, temp sensor, GPS  and i need the readings from the sensors and gps to be sent to the other arduino's LCD. i just dont know how to go about doing it and i was wondering if there is someone that could help guide me.
//sender
int inpin=A0;
int TEMP=0;
int heartratepin=A1;
int difference;
int newHeartReading = 0;
int lastHeartReading = 0;
int measurements[5] = {0,0,0,0,0};
int historySize = 5;
int recenttotal = 0;
int Index = 0;
boolean highChange = false;
int minimumdifference = 2;
int num[5];
int average=0;
// Heart rate timing
long lastHeartbeatTime = 0;
long debounceDelay = 150;       // the debounce time; increase if the output flickers
int currentHeartrate = 0;
int lastHeartrate = 0;
//Heart rate LED
//int ledState = LOW;
//long ledOnMillis = 0;
//long ledOnInterval = 50;
int slope = ((newHeartReading-lastHeartReading)/(debounceDelay-lastHeartrate));
// Debugging string
String debugOutput = "";
void setup() {
   // start serial port at 9600 bps:
   Serial.begin(9600);
    pinMode(heartratepin,INPUT);
   establishContact();
void establishContact() {
while (Serial.available() <= 0) {
      Serial.println("hello");   // send a starting message
      delay(300);
void loop() {
   // read analog input, divide by 4 to make the range 0-255:
   int analogValue = analogRead(inpin);
   float millivolts = (analogValue/1024.0)*5000;
   float celsius = millivolts/10-50;
   Serial.println(analogValue);
   Serial.print(celsius);
   Serial.print("c");
   Serial.print((celsius*9)/5+32);
   Serial.print("F");
   newHeartReading = analogRead(heartratepin);
    //calculation
  difference = newHeartReading - lastHeartReading;
  lastHeartReading = newHeartReading;
  // Find new recent total
  recenttotal = recenttotal - measurements[Index] + difference;
  // replace indexed recent value
  measurements[Index] = difference;
   //index + 1 index = (index + 1) % historySize;
    for (int i=0; i<5; i=i+1){
               num[i]=0;
              if (Index>=5)
              Index=0;
              //calculating the average
              average=recenttotal/5;
              Serial.println(average);
              delay(10);
  if (recenttotal >= minimumdifference)
    // possible heart rate check timing
    if (millis() - lastHeartbeatTime >= debounceDelay)   // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
  // Heart rate
// digitalWrite(ledPin, HIGH);
  currentHeartrate = 60000 / (millis() - lastHeartbeatTime);
    lastHeartbeatTime = millis();
   Serial.println(newHeartReading);
      if (currentHeartrate <= 200)// && currentHeartrate > 20)
                  Serial.print("Heart Rate =" + String(currentHeartrate) + "  ");
                  delay(10);
            if (currentHeartrate <= 39 and currentHeartrate >= 0){
                  Serial.print("I Am Sick");
                 delay(10);
          if (currentHeartrate<= 79 and currentHeartrate >= 70){
                  Serial.print("Night Mare");
                delay(10);
            if (currentHeartrate <= 69 and currentHeartrate >= 40){
                  Serial.print("kid Is At Sleep");
              delay(10);
              if (currentHeartrate <= 99 and currentHeartrate >= 80){
                  Serial.print("Kid Is Resting");
                delay(10);
                if (currentHeartrate <= 119 and currentHeartrate >= 100){
                  Serial.print("Kid Is Playing");
                  if(currentHeartrate > 120){
                    Serial.print(" The Kid Is Having ");
                    //lcd.setCursor(0,1);
                    //lcd.print(" A Heart Attack");
   // print different formats:
   Serial.write(analogValue);  // Print the raw binary value
   Serial.print('\t');             // print a tab
   Serial.write(newHeartReading);  // Print the raw binary value
//receiver
#include <SPI.h>
#include <LiquidCrystal.h>
int inpin=A0;
LiquidCrystal lcd(30,31,32,33,34,35);
void setup()
  lcd.begin(16,2);
  Serial.begin(9600);
void loop()
  if(Serial.available()>0)
    int inByte=Serial.read();
    int analogValue=analogRead(inpin);
    lcd.print(analogValue);
    lcd.print(",");
    int newHeartReading=analogRead(heartratepin);
    lcd.print(newHeartReading);
    lcd.print(",");
i dont know what i am doing wrong
  • bobcroft
    bobcroft over 10 years ago in reply to Former Member +2
    Richard, in order to see the Easy Transfer library just Google Arduino Easy Transfer library. There are informative notes and code examples. To answer your other question, yes you can display the data…
  • clem57
    clem57 over 10 years ago +1
    ricardo240 I cannot comment on the sender code since it has many things going on. But here are the things I would do: Make sure the pins are connected as TX to RX on the UART on sender and UART on receiver…
  • clem57
    clem57 over 10 years ago in reply to Former Member +1
    To understand: 1) the sensors are reading fine. 2) The UNO sends on UART to the MEGA UART but does not work. What pins are connected on each to the other? 3) The code you sent looks like snippets especially…
  • clem57
    0 clem57 over 10 years ago
    ricardo240
    1. Make sure the pins are connected as TX to RX on the UART on sender and UART on receiver. This hooks the sender to the receiver in both directions.
      TX   ======>   RX
      RX  <======   TX
    2. Check the pins are correct for serial communication.
    3. Serial is your debugging to USB to windows, Serial1 is the UART on Arduino. I would expect these:
        Serial.begin(9600); <== USB and Serial1.begin(9600); <=== Arduino other
    4. Where is the setup/includes? The serial interface needs to be defined saying which pins to use.
    Clem
  • gadget.iom
    0 gadget.iom over 10 years ago
    What model of Arduino are you using?
    0 Former Member over 10 years ago in reply to gadget.iom
    Am using a uno for the sender and a mega for the receiver
  • clem57
    0 clem57 over 10 years ago in reply to Former Member
    On the UNO, can you use the UART and have no debugging code or USB support? Paul raises a valid concern because of limited UART.
    Clem
    0 Former Member over 10 years ago in reply to clem57
    Yes, i am using a 9v battery source to power to uno so that i wouldnt have to use the usb support as the powering source
    The reading is taking place, am just having problems getting it to the mega for it to be displayed on the lcd screen
  • clem57
    To understand:
    3) The code you sent looks like snippets especially receiver and guessing not complete. Can you attach full sketch from both? If you wish put in private blog between us only.
    4) Does the serial code work on the UNO when sent to USB? If it does that would resolve half the issue.
    5) Did you check anything from my first comment?
    Clem
  • neilk
    0 neilk over 10 years ago
    ricardo240  Hi Richard,
    Your problem seems to me to be the classic one of "can't see the wood for the trees"
    I assume that you can read the sensors correctly AND display the results on the Serial Monitor of the UNO
    I assume that you can correctly display similar data on the LCD connected to your MEGA.
    So, if I were you I would start a NEW simple sketch to transmit a SIMPLE KNOWN item of data from the UNO to the MEGA, displaying the received item of data on the MEGA Serial Monitor.
    Once you have achieved this, using the help that clem57 has already offered you, then you can make the data more complex and so develop the code in a stepwise fashion..
    It's how I do all my development work - identify the most difficult component and solve that FIRST.
    Hope this helps
    Neil
    1. yes the sensors are working
    2. yes, i am using on the uno pin 0 and 1 for the tx and rx. on the mega i am using pin 18 and 19 for tx and rx
    3.i will send u the code now
    4.yes it does work with the usb connect it self
    5.yes i did.
    i started with the temp sensor alone
    #include <SoftwareSerial.h>
    //reciever
    #include <SPI.h>
    SoftwareSerial mySerial(1,0);
    int inpin=A0;
    void setup()
      lcd.begin(16,2);
      Serial.begin(9600);
      //Serial1.begin(9600);
    establishContact();
    while (Serial.available()== 1) {
         // Serial.println("hello");   // send a starting message
          delay(300);
    void loop()
      if(Serial.available()==1)
        int inbyte =Serial.read();
        int sensorValue=analogRead(A0);
        lcd.print(sensorValue);
        lcd.print(",");
    int inpin=A0;
    int TEMP=0;
    int sensorValue;
    SoftwareSerial mySerial(18,19);
    void setup() {
       Serial.begin(9600);
       // pinMode(heartratepin,INPUT);
      // establishContact();
    //void establishContact() {
    //while (Serial.available()== 1) {
       //   delay(300);
    void loop() {
      if (mySerial.available())
      Serial.write(mySerial.read());
      if (Serial.available())
       int sensorValue = analogRead(inpin);
       float millivolts = (sensorValue/1024.0)*5000;
       Serial.println(sensorValue);
       Serial.print("c");
       Serial.print("F");
      mySerial.write(sensorValue);  // Print the raw binary value
    0 Former Member over 10 years ago in reply to neilk
    i did but it still didnt display anything on the lcd
    this is the sample code that i decided to use as an experiment to get the communication working because i believe if this works then i can proceed to getting the rest of the things i need to do added to it.
    her is the code
    int inpin=A0;
    int TEMP=0;
    int sensorValue;
    void setup() {
       Serial.begin(9600);
       //   delay(300);
    void loop() {
       Serial.print("c");
       Serial.print("F");
    //reciever
    #include <SPI.h>
    int inpin=A0;
    void setup()
      lcd.begin(16,2);
      Serial.begin(9600);
    establishContact();
          delay(300);
    void loop()
        lcd.print(",");
