Avnet Boards General Ultra96-V2 (Zynq MPSoC ZU3EG) 2018.3 no display output
  • Subscribers 372 subscribers
  • Views 1457 views
  • ultra96v2
  • ultra96-v2
  • zedboardcmty
occam25
occam25 over 6 years ago
I am not getting any desktop output from the display port. I installed the image found in http://avnet.me/ultra96-v2-oob-8GB and it is booting but nothing comes out to the screen. I am using a display port screen (Samsung SyncMaster SA650) and a miniDP-DP cable.
This is a piece of dmesg with display related messages:
[    3.331212] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    3.341925] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    3.349968] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    3.358423] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.370867] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.383573] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[    3.393762] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000    <- doesn't look good..
[    3.400780] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.407385] [drm] No driver support for vblank timestamp query.
[    3.413380] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008b28168)
[    4.497535] [drm] Cannot find any crtc or sizes
[    4.502273] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[    4.510378] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[    4.520023] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[    4.531497] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:1 protocol:3 pll_locked:yes
[    4.541543] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.547032] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.554913] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
I haven't found any solution in the web, if anyone can help it will be apreciated!
  • drozwood90
    drozwood90 over 6 years ago +1
    Hi there, Are you able to test with a different monitor? Have you seen these troubleshooting steps from Xilinx? https://forums.xilinx.com/t5/Embedded-Linux/OF-graph-no-port-node-found-in-amba-xilinx-drm…
  • drozwood90
    drozwood90 over 6 years ago in reply to occam25 +1
    Hi there, I was thinking, in the mean time, you could also try a different version of the bootable images. That is a quick and easy test as you would only need to replace all the files on the two SDCARD…
  • drozwood90
    Hi there,
    https://forums.xilinx.com/t5/Embedded-Linux/OF-graph-no-port-node-found-in-amba-xilinx-drm/td-p/813934
    Included in that link is a list of compatible monitors.  I can say that it is rare to find an incompatible monitor, but it does happen.
    There is also a correction to one of the commands in the very last post.
    --Dan
    If you found my reply helpful, please mark as such, if my reply resolved your issue, please mark resolved!
  • occam25
    occam25 over 6 years ago in reply to drozwood90
    Hi Daniel,
    thanks for answering. Yes, I read that post and tried their solution, but booting with drm.debug=0xe generates a kernel panic in my board and I don't find the modetest executable neither. Maybe because I am using different version (2018.3)?
    I will try to find another monitor to test
    br,
    javi
  • drozwood90
    Hi there,
    I was thinking, in the mean time, you could also try a different version of the bootable images.  That is a quick and easy test as you would only need to replace all the files on the two SDCARD partitions.
    You can find the latest on the product page as well as on this consolidated page:
    http://avnet.me/DBA_BSPS_PLATFORMS_2019p2
    Which quick and easy, I see this as a uncertain test.  I really think changing the monitor would be a more certain response.  I personally use the On-Lap 1303H monitor.  I purchased from Amazon.
    --Dan
  • occam25
    Hi Daniel,
    you were right. I tested a different monitor (Benq GW2765) and it worked!  : )
    I can't understand why there are incompatibility issues with the other since they use the same DP standard.. that's very annoying, but at least I have now the display output I needed for a training
    Thanks for your help!
    Javi
