Avnet Boards General ZedBoard MAC Address
  • Subscribers 373 subscribers
  • Views 1787 views
100alexj
100alexj over 8 years ago
Where can I find the MAC address of my ZedBoard? I need the MAC address so that I can store it into my networks DHCP lookup table. Does a certain piece of code need to be running in order for the board to receive a MAC address? The board is right now connect to my network via an Ethernet cable.
Any help will be greatly appreciated.
Thank you,
-Alex
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Alex,
    The MAC address is defined within the kernel device tree on PetaLinux systems.  This means, once you define it once for one board, it is the same for every other board that you load that PetaLinux build onto.
    Here is the Xilinx official response for customers looking to assign MAC address across their boards:
    https://www.xilinx.com/support/answers/53476.html
    Xilinx is working on a way to pull the MAC ID from an I2C EEPROM (like PicoZed and UltraZed carriers) so adding a MAC ID EEPROM will be supported option at some point in the future.  This is economically the best way to go for customers manufacturing under 10,000 pieces at a time.
    Under Linux your current MAC ID will be defined under HWaddr.
    --Josh
  • 100alexj
    0 100alexj over 8 years ago in reply to jafoste4
    Hi Josh,
    Thank you for the responses and great information. It now makes sense to why I couldn't see the MAC address. I will download PetaLinux and follow the provided instructions.
    Thanks again,
    -ALex
  • 100alexj
    Sorry to open this back up, but I still have a few questions.
    When I plug in the SD card that comes with the ZedBoard and run the code in PuTTY I notice the MAC address is 00:0A:35:00:01:22. When the SD card is not plugged in I am assuming the ZedBoard does not have a MAC address. Is my assumption correct? Is there a way to assign a permanent MAC address to the board to where it stays the same upon reset and without the SD card?
    FYI I am using a windows machine and currently do not have access to Linux.
    Thank you,
    -Alex
  • jafoste4
    Hello Alex,
    You could try installing the Linux image into the QSPI so you do not need a SD Card.
    --Josh
