MaaXBoard Hardware Design MaaXBoard Schematics and BOM
  • Replies 14 replies
  • Subscribers 358 subscribers
  • Views 3545 views
  • maaxboard
fouad_jh
fouad_jh over 3 years ago
I am trying to find MaaXBoard shcematics with no luck. Any links?
  • msaka
    msaka over 2 years ago in reply to jiedummy +2
    You may contact your Avnet FAE for assistance in obtaining schematics through an NDA. This document may also be helpful to get started. MaaXBoard-8ULP-User-Guide-v1.0.pdf (avnet.com)
  • bidrohini
    bidrohini over 3 years ago +1
    A block diagram is available here: MaaxBoard RT Schematic and BOM are not available I guess. The board is not open source.
  • fouad_jh
    fouad_jh over 3 years ago in reply to bidrohini +1
    Thanks bidrohini . Even if it is not open source, schematics are really handy to havefor development. i.e MaaXBoard has marking for a connectore (J22)! I couldn't find any details about.
  • bidrohini
  • fouad_jh
  • jiedummy
    jiedummy over 2 years ago in reply to fouad_jh
    Thank you for checking.  I almost order the board.  Since there is no schematics, I will order imx8ulp eval kit from NXP.
  • msaka
    Have you considered the MaaXBoard 8ULP from Avnet? It is significantly cheaper than the NXP EVK.
    https://www.avnet.com/wps/portal/us/products/avnet-boards/avnet-board-families/maaxboard/maaxboard-8ulp/
    Regards.
  • tjaekel
    tjaekel over 2 years ago in reply to msaka
    Schematics for Maaxboard-RT are not published.
    If you need a (correct) pin assignment (pinmux) table (user guide is not really correct):
    Maaxboard-RT pinmux table
  • msaka
    msaka over 2 years ago in reply to tjaekel
    Is there anything in particular that you are having trouble with or is this a general question regarding schematic availability?
    Regards
  • tjaekel
    Hi bodrohini and jiedummy.
    I am using Maaxboard-RT (and have several projects published). If I can help (w/o schematics)...
    I like the board: pretty powerful, and I have designed a HAT (breakout board for it, for my needs, e.g. QSPI).
  • msaka
    msaka over 2 years ago in reply to fouad_jh
    I can't seem to find connector J22 on the MaaXBoard RT, could you referring to a different board?
  • jiedummy
    jiedummy over 2 years ago in reply to msaka
    without schematics, avnet maaxboard 8ulp board is black box only.  it is not the issue of cost.
  • fouad_jh
    fouad_jh over 2 years ago in reply to msaka
    My question was about MaaxBoard AES-MC-SBC-IMX8M-G not MaaxBoard RT
