MiniZed Hardware Design AXI Transer between linux and FPGA
  • Replies 7 replies
  • Subscribers 359 subscribers
  • Views 1289 views
shanbhagm
shanbhagm over 8 years ago
My requirement is to transfer data from FPGA to ARM(linux) and back. I want to use the AXI bus interface.
Can some one point me to aworking example of data transfer from linux to the FPGA and vise versa.
A quick help will be appreciable.
-Madhav
  • jafoste4
    0 jafoste4 over 8 years ago
    What hardware are you using?
    Josh
  • shanbhagm
    0 shanbhagm over 8 years ago in reply to jafoste4
    We are using Minized-7Z007-G. We have recently prurchased .
  • shanbhagm
  • jafoste4
    My suggestion would be for you to take the free Integrating Sensors on MiniZed with Petalinux Speedway we offer. It can be found here
    http://zedboard.org/support/trainings-and-videos
    --Josh
  • shanbhagm
    I have followed the step with Xilinx_Vivado_SDK_Web_2018.2_0614_1954_Lin64.bin and petalinux-v2018.2-final-installer.run.
    When I try to build peta linux I get the following error in Lab1 .
    Can you help me on same.
      training@training-VirtualBox:~/labs/lab1/petalinux-min$ petalinux-config  --get-hw-description=~/hdl/Projects/minized_sensor_fusion/MINIZED/minized_sensor_fusion.sdk
      INFO: Getting hardware description...
      INFO: Rename minized_sensor_fusion_hw.hdf to system.hdf
      [INFO] generating Kconfig for project
      [INFO] menuconfig project
      /home/training/labs/lab1/petalinux-min/build/misc/config/Kconfig.syshw:30:warning: defaults for choice values not supported
      /home/training/labs/lab1/petalinux-min/build/misc/config/Kconfig:597:warning: config symbol defined without type
      *** End of the configuration.
      *** Execute 'make' to start the build or try 'make help'.
      [INFO] sourcing bitbake
      [INFO] generating plnxtool conf
      [INFO] generating meta-plnx-generated layer
      [INFO] generating machine configuration
      [INFO] generating bbappends for project . This may take time !
      [INFO] generating u-boot configuration files
      [INFO] generating kernel configuration files
      [INFO] generating kconfig for Rootfs
      [INFO] oldconfig rootfs
      [INFO] generating petalinux-user-image.bb
      training@training-VirtualBox:~/labs/lab1/petalinux-min$ petalinux-build
      [INFO] building project
      INFO: bitbake petalinux-user-image
      Parsing recipes: 100% |########################################################################################################################| Time: 0:01:22
      Parsing of 2552 .bb files complete (0 cached, 2552 parsed). 3425 targets, 148 skipped, 0 masked, 0 errors.
      WARNING: No recipes available for:
        /home/training/labs/lab1/petalinux-min/project-spec/meta-plnx-generated/recipes-bsp/device-tree/device-tree-generation_%.bbappend
        /home/training/labs/lab1/petalinux-min/project-spec/meta-user/recipes-bsp/device-tree/device-tree-generation_%.bbappend
      NOTE: Resolving any missing task queue dependencies
      Initialising tasks: 100% |#####################################################################################################################| Time: 0:00:09
      Checking sstate mirror object availability: 100% |#############################################################################################| Time: 0:00:18
      NOTE: Executing SetScene Tasks
      NOTE: Executing RunQueue Tasks
      ERROR: device-tree-xilinx+gitAUTOINC+f38738e568-r0 do_compile: Function failed: do_compile (log file is located at /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_compile.11307)
      ERROR: Logfile of failure stored in: /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_compile.11307
      Log data follows:
      | DEBUG: Executing shell function do_compile
      | /home/training/labs/lab1/petalinux-min/build/../components/plnx_workspace/device-tree/device-tree/system-top.dts:34:28: fatal error: system-user.dtsi: No such file or directory
      | compilation terminated.
      | WARNING: /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/run.do_compile.11307:1 exit 1 from 'gcc -E -nostdinc -Ulinux -x assembler-with-cpp -I/home/training/labs/lab1/petalinux-min/build/../components/plnx_workspace/device-tree/device-tree -I/home/training/labs/lab1/petalinux-min/build/tmp/work-shared/plnx-zynq7/kernel-source/include -I/home/training/labs/lab1/petalinux-min/build/tmp/work-shared/plnx-zynq7/kernel-source/include -I/home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0 -o `basename ${DTS_FILE}`.pp ${DTS_FILE}'
      | ERROR: Function failed: do_compile (log file is located at /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_compile.11307)
      ERROR: Task (/opt/pkg/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_compile) failed with exit code '1'
      NOTE: Tasks Summary: Attempted 2970 tasks of which 2847 didn't need to be rerun and 1 failed.
      Summary: 1 task failed:
      Summary: There was 1 WARNING message shown.
      Summary: There was 1 ERROR message shown, returning a non-zero exit code.
      ERROR: Failed to build project
  • jafoste4
    Please use the suggested tool set to complete this Speedway. That would be 2017.4 or 2017.1 tool sets.
    --Josh
  • shanbhagm
    I installed 2017.4 and I get same error:
    Are you sure it worked with 2017.4?
    training@training-VirtualBox:~/labs/lab1/petalinux-min$ petalinux-config --get-hw-description=/home/training/hdl/Projects/minized_sensor_fusion/MINIZED/minized_sensor_fusion.sdk
    cp: omitting directory '/home/training/hdl/Projects/minized_sensor_fusion/MINIZED/minized_sensor_fusion.sdk/minized_sensor_fusion_bsp'
    cp: omitting directory '/home/training/hdl/Projects/minized_sensor_fusion/MINIZED/minized_sensor_fusion.sdk/minized_sensor_fusion_hw'
    cp: omitting directory '/home/training/hdl/Projects/minized_sensor_fusion/MINIZED/minized_sensor_fusion.sdk/zynq_fsbl_app'
    cp: omitting directory '/home/training/hdl/Projects/minized_sensor_fusion/MINIZED/minized_sensor_fusion.sdk/zynq_fsbl_bsp'
    /home/training/labs/lab1/petalinux-min/build/misc/config/Kconfig:568:warning: config symbol defined without type
    configuration written to /home/training/labs/lab1/petalinux-min/project-spec/configs/config
    ~/labs/lab1/petalinux-min/build/misc/plnx-generated ~/labs/lab1/petalinux-min
    Generate rootfs kconfig
    Loading cache: 100% |############################################| Time: 0:00:01
    Loaded 3258 entries from dependency cache.
    Parsing recipes: 100% |##########################################| Time: 0:00:02
    Parsing of 2466 .bb files complete (2429 cached, 37 parsed). 3259 targets, 226 skipped, 0 masked, 0 errors.
    Initialising tasks: 100% |#######################################| Time: 0:00:07
    Checking sstate mirror object availability: 100% |###############| Time: 0:00:31
    ERROR: device-tree-generation-xilinx+gitAUTOINC+3c7407f6f8-r0 do_configure: Function failed: do_configure (log file is located at /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/log.do_configure.31780)
    ERROR: Logfile of failure stored in: /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/log.do_configure.31780
    Log data follows:
    | DEBUG: Executing python function sysroot_cleansstate
    | DEBUG: Python function sysroot_cleansstate finished
    | DEBUG: Executing shell function do_configure
    | MISC_ARG is  -yamlconf /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/device-tree-generation.yaml
    | APP_ARG is  -app "device-tree"
    | cmd is: xsct /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/dtgen.tcl -ws /home/training/labs/lab1/petalinux-min/build/../components/plnx_workspace/device-tree -pname device-tree-generation -rp /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/git -processor ps7_cortexa9_0 -hdf /home/training/labs/lab1/petalinux-min/build/tmp/deploy/images/plnx_arm/Xilinx-plnx_arm.hdf -arch 32  -app "device-tree"  -yamlconf /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/device-tree-generation.yaml
    | CRITICAL WARNING: [Board 49-71] The board_part definition was not found for em.avnet.com:minized:part0:1.2. The project's board_part property was not set, but the project's part property was set to xc7z007sclg225-1. Valid board_part values can be retrieved with the 'get_board_parts' Tcl command. Check if board.repoPaths parameter is set and the board_part is installed from the tcl app store.
    | INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds
    | hsi::open_hw_design: Time (s): cpu = 00:00:05 ; elapsed = 00:00:06 . Memory (MB): peak = 420.281 ; gain = 83.949 ; free physical = 144 ; free virtual = 6269
    | ERROR: [Common 17-55] 'get_property' expects at least one object.
    | Resolution: If [get_<value>] was used to populate the object, check to make sure this command returns at least one valid object.
    | ERROR: [Hsi 55-1545] Problem running tcl command ::sw_device_tree::post_generate : ERROR: [Common 17-55] 'get_property' expects at least one object.
    |     while executing
    | "get_property IP_NAME [get_cells -hier $proc_name]"
    |     (procedure "update_cpu_node" line 23)
    |     invoked from within
    | "update_cpu_node $os_handle"
    |     (procedure "::sw_device_tree::post_generate" line 4)
    |     invoked from within
    | "::sw_device_tree::post_generate device_tree"
    | ERROR: [Hsi 55-1443] Error(s) while running TCL procedure post_generate()
    | generate_target failed
    |     while executing
    | "error "generate_target failed""
    |     invoked from within
    | "if {[catch {hsi generate_target -dir $project} res]} {
    |     (file "/home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/dtgen.tcl" line 33)
    | WARNING: /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/run.do_configure.31780:1 exit 1 from 'eval xsct /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/dtgen.tcl -ws /home/training/labs/lab1/petalinux-min/build/../components/plnx_workspace/device-tree -pname device-tree-generation -rp /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/git -processor ps7_cortexa9_0 -hdf /home/training/labs/lab1/petalinux-min/build/tmp/deploy/images/plnx_arm/Xilinx-plnx_arm.hdf -arch 32 ${APP_ARG} ${MISC_ARG}'
    | ERROR: Function failed: do_configure (log file is located at /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/log.do_configure.31780)
    ERROR: Task (/opt/petalinux-v2017.4-final/components/yocto/source/arm/layers/meta-xilinx-tools/recipes-bsp/device-tree/device-tree-generation_git.bb:do_configure) failed with exit code '1'
    ERROR: fsbl-2017.4+gitAUTOINC+77448ae629-r0 do_configure: Function failed: do_configure (log file is located at /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/temp/log.do_configure.9413)
    ERROR: Logfile of failure stored in: /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/temp/log.do_configure.9413
    Log data follows:
    | MISC_ARG is  -yamlconf /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/fsbl.yaml
    | APP_ARG is  -app "Zynq FSBL"
    | cmd is: xsct /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/app.tcl -ws /home/training/labs/lab1/petalinux-min/build/../components/plnx_workspace/fsbl -pname fsbl -rp /opt/petalinux-v2017.4-final/tools/hsm/data/embeddedsw -processor ps7_cortexa9_0 -hdf /home/training/labs/lab1/petalinux-min/build/tmp/deploy/images/plnx_arm/Xilinx-plnx_arm.hdf -arch 32  -app "Zynq FSBL"  -yamlconf /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/fsbl.yaml
    | Starting xsdk. This could take few seconds... Picked up _JAVA_OPTIONS: -Duser.home=/home/training/labs/lab1/petalinux-min/build/tmp/xsctenv
    | done
    | Importing project fsbl... [DONE]
    | hsi::open_hw_design: Time (s): cpu = 00:00:05 ; elapsed = 00:00:06 . Memory (MB): peak = 359.957 ; gain = 82.336 ; free physical = 133 ; free virtual = 4899
    | INFO: create app using fsbl_hwproj project
    | Project with name 'fsbl' already exists in workspace.
    | Failed to create Application project fsbl.Project with name fsbl already exists in workspace.
    |     while executing
    | "error [dict get $msg err]"
    |     (procedure "xsdk_eval" line 15)
    |     invoked from within
    | "xsdk_eval $chan "Xsdk" createProject "o{$fmt}" e [list $data]"
    |     (procedure "createapp" line 76)
    |     invoked from within
    | "createapp -name $params(pname) -proc $params(processor)  -hwproject $params(hwpname)  -os $params(osname) -lang c -app $params(app) -arch $params(arch..."
    |     invoked from within
    | "if { $params(ws) ne "" } {
    | #Local Work Space available
    | setws $params(ws)
    | if { [catch {importprojects $params(ws)} result] } {
    | puts "XSCTHELPER IN..."
    |     (file "/home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/app.tcl" line 120)
    | WARNING: /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/temp/run.do_configure.9413:1 exit 1 from 'eval xsct /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/app.tcl -ws /home/training/labs/lab1/petalinux-min/build/../components/plnx_workspace/fsbl -pname fsbl -rp /opt/petalinux-v2017.4-final/tools/hsm/data/embeddedsw -processor ps7_cortexa9_0 -hdf /home/training/labs/lab1/petalinux-min/build/tmp/deploy/images/plnx_arm/Xilinx-plnx_arm.hdf -arch 32 ${APP_ARG} ${MISC_ARG}'
    | ERROR: Function failed: do_configure (log file is located at /home/training/labs/lab1/petalinux-min/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/fsbl/2017.4+gitAUTOINC+77448ae629-r0/temp/log.do_configure.9413)
    ERROR: Task (/opt/petalinux-v2017.4-final/components/yocto/source/arm/layers/meta-xilinx-tools/recipes-bsp/fsbl/fsbl_git.bb:do_configure) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 2343 tasks of which 1873 didn't need to be rerun and 2 failed.
    Summary: 2 tasks failed:
    Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
