PicoZed Hardware Design board selection question
  • Subscribers 360 subscribers
  • Views 798 views
I like to purchase a development board for personal use, mainly to learn on the embedded processor side under petalinux.  any recommendations? nothing too expensive.  what the main difference between pico/micro board other than size?
  • zedhed
    0 zedhed over 11 years ago
    Hi s002wjh,
    For anyone looking to get started with Zynq, MicroZed is hands-down one of the best low-cost options out there.  By purchasing the Eval Kit (look for part number  AES-Z7MB-7Z010-G) you get a board that you can do embedded processor work on without needing a carrier board for 199USD.
    http://microzed.org/buy
    If you decide to move onto doing work with the programmable logic, you can still do this without a carrier.  The point at which you need a carrier is when you want to start using the programmable logic AND the flexible IOs that are attached to it.
    At that point, if you are simply doing simple circuit prototyping, you might be able to utilize a MicroZed Breakout Carrier for 59 USD.
    If you are looking to do low-cost peripherals like Pmods, then it is recommended that you look at the MicroZed I/O Carrier for 149 USD.
    If you are looking to do high performance FMC expansion modules, then you will want to look at the MicroZed FMC Carrier for 149 USD.
    The board sizes between MicroZed and PicoZed are actually the same.  For PicoZed, many of the outside world connectors have been moved down to the carrier board so the PicoZed SOM has a lower vertical profile than MicroZed.
    -Kevin
    0 e14 Contributor over 11 years ago in reply to zedhed
    hi is AES-Z7MB-7Z010-G  this microzed SBC?
    http://microzed.org/product/microzed-sbc
    the buy option only has part#, doesn't has description
    thanks
    This part number is the MicroZed Evaluation kit, which includes a 'standard' commercial temp 7010 MicroZed along with a node/device locked Xilinx Vivado tool voucher, a microSD Card and a MicroUSB cable. http://microzed.org/sites/default/files/PB-AES-Z7MB-7Z010-G-v3.pdf
    AES-Z7MB-7Z010-SBC-G is the part number for a commercial temp 7010 MicroZed SBC SOM. It is the SOM only with no SD Card, cable or voucher.  It is listed in a separate section on the 'Buy' page just below the MicroZed section.
    If you click the 'Buy' button it will take you to a page with a description.
    -Gary
  • ghanudave
    0 ghanudave over 9 years ago
    I need help with Embedded SDR development board parts and SBC board that go with the development process.
    I can buy PicoZed SDR SOM Z7035/AD9361 Development Kit. But my question is what else I need to buy in order to
    do SDR development - I need help with all that I need including software if any
  • mbrown
    0 mbrown over 9 years ago in reply to ghanudave
    Let's pick this discussion up on the PicoZed SDR Forum.  I started a topic here -- http://picozed.org/content/what-do-i-need-start-picozed-sdr-development
    /Matt
