PicoZed Hardware Design Picozed download to Flash issue
  • Subscribers 357 subscribers
  • Views 1848 views
  • picozed
jfioriglio
jfioriglio over 4 years ago
We have been successful downloading FLASH with Vitis 2020.1.  During a download session, the user cancelled the download in midstream and the board became a brick.
We tried to re-download the Flash and we get  message: uboot error and Flash programming initialization has failed.
Does any one know how we fix this issue so we can download again?
Also we cannot read from Flash thru the JTAG debugger.
  • narrucmot
    0 narrucmot over 4 years ago
    You should be able to rescue the board by using JTAG and TFTP to boot a known-good Linux OS image and then use the Linux flash utilities to erase and reprogram the QSPI.  Don't forget to reset the boot mode switches to JTAG before attempting this.  You can download a known-good PetaLinux BSP for the PicoZed here:
    http://avnet.me/zedsupport
    Instructions for booting via JTAG can be found here:
    https://github.com/Avnet/petalinux/blob/2020.1/documentation/pz/how_to_boot.txt
    I hope this helps.
    --Tom
  • jfioriglio
    0 jfioriglio over 4 years ago
    Is there a way to do this without an ethernet connection?  Can we do it over JTAG only?  It is our only interface to PICOZED Card.
  • bhfletcher
    0 bhfletcher over 4 years ago in reply to jfioriglio
    You should be able to do this over JTAG only if you have an MCS file. If you have access to the PicoZed FMC V2 Carrier, then you could follow these Restore instructions to overwrite QSPI and eMMC back to their factory state.
    PZ_RevC_Restore_v2_0_150612.zip
    Bryan
