Software Application Development use pcap in sdk
  • Subscribers 364 subscribers
  • Views 621 views
use pcap in sdk
Hello everybody
I am a beginner using zedboads.
After reviewing some user manuals and application notes, I still don't know how to use pcap.
My goal is to design a hardware-software that partially I can reconfigure the hardware in software.
Regards
Amin
  • zedhed
    0 zedhed over 11 years ago
    Hi Amin,
    Partial reconfiguration is a pretty advanced topic but it can be done if you do some careful planning in your logic design.  The best place to start would be to take a look at XAPP1231:
    http://www.wiki.xilinx.com/XAPP1231+-+Partial+Reconfiguration+of+a+Hardware+Accelerator+with+Vivado+Design+Suite
    Loading the partial bitstream to the PL is most easily done from Linux so if you are planning on running your software from Linux most of the software hooks you will need are already in place.
    -Kevin
    0 e14 Contributor over 11 years ago in reply to zedhed
    Hi Kevin
    Thanks for the reply.
    Actually XAPP1231 was the first thing I did about PR; but it doesn't use Processing, so I need a Hardware-software design with ability to change the hardware module (PR) with Processor.
    Regards
    Amin
  • zedhed
    Hi Amin,
    Perhaps I am misunderstanding you.  XAPP1231 uses Linux running on the ARM cores of Zynq to load the PR bitstream across the PCAP interface.  Is this different than what you are looking for?
    Can you please elaborate on what you mean when you say "it doesn't use Processing"?
    -Kevin
    Hi Kevin
    So sorry, I made a mistake; I had done UG947 previously which only includes of PR in PL not pS, and after that I tried to start XAPP1231; I encountered a problem when I wanted to validate the block design, a problem about HDMI wiring that I couldn't solve it, besides I only have a zedboard which XAPP1231 is not for that, so I did't work on it anymore. but maybe I need to start it again.
    Sorry for misunderstanding.
    by the way, don't you know any other app note about driving pcap for PR?
    Regards
    Amin
