Ultra96 Hardware Design Anyone try flashing a boot image on a Kingston 32GB Micro SD Card?
  • Subscribers 366 subscribers
  • Views 712 views
  • ultra96-v2
kiranshashiny
kiranshashiny over 7 years ago
I flashed the "ultra96v2_oob_2018_3_190530.img" onto a Kingston 32GB ( first I formatted the 32 GB Micro SD Card to MSDOS FAT format , MBR)
Used the Balena Etcher to flash it and it failed !
Question :
1. Is there another way to flash/burn the image onto the SD Card, other than Balena.
2. Is Kingston 32 GB an accepted SD Card for Ultra 96v2 ?
3. What are the format parameters for the SD Card. There is ExFAT and MSDOS. Any recommendations.
Appreciate any inputs.
  • kiranshashiny
    I had to flash a new MicroSD Card as I did not the factory default MicrSDCard, so resorted to downloading new image and flashing to the SDCard.
  • jafoste4
    jafoste4 over 7 years ago in reply to kiranshashiny
    When choosing an SD Card I recommend users follow the SD Card Advice document we make available.
    SD Card Advice V2 for Zynq and Zynq UltraScale+ SoC Products | Zedboard
    Please let me know your results after your testing.
    1. you can use win32diskimager
    2.I cannot say for certain if it will work as we have not tested a 32GB sd card at this point. I believe we did test a 32GB Delkin sd card however.
    3. We typicall make a 1GB boot FAT32 patition and the rest EXT4 to house the rootfs.
    Thx,
    Josh
