Ultra96 Hardware Design Ultra 96 v2 Spontaneous Failure?
  • Subscribers 367 subscribers
  • Views 1052 views
  • ultra96-v2
  • SD card
  • mmc
mojo_jojo
mojo_jojo over 7 years ago
One of the Ultra 96 v2 boards I have worked fine for couple of hours, then suddenly it crashed while running Linux.
Afterwards, I always get the following on the serial port:
U-Boot 2018.01 (May 30 2019 - 17:43:24 +0000)
Model: Avnet Ultra96 Rev1
Board: Xilinx ZynqMP
I2C:   ready
DRAM:  2 GiB
EL Level:       EL2
Chip ID:        zu3eg
Watchdog: Started
MMC:   sdhci_send_command: MMC: 0 busy timeout increasing to: 200 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 400 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 800 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 1600 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 3200 ms.
sdhci_send_command: MMC: 0 busy timeout.
mmc_init: -70, time 7440
mmc@ff160000 - probe failed: -70
mmc_init: -70, time 7414
** Bad device mmc 0 **
Using default environment
In:    serial@ff010000
Out:   serial@ff010000
Err:   serial@ff010000
Bootmode: SD_MODE
Net:   Net Initialization Skipped
No ethernet found.
U-BOOT for ultra96v2-oob-2018-3
Hit any key to stop autoboot:  0
no mmc device at slot 0
I tried other SD cards but wasn’t able to fix the issue. The SD card that was in this board works fine on other Ultra 96 v2 boards. This appears to be a hardware failure. Could I get the board replaced by Avnet?
  • clem57
    0 clem57 over 7 years ago
    Have you seen this?image
    I had that exact same problem with one of my development boards. It was the clock speed setting of the SD card controller (sdhci0). It was set to 25 MHz which is too slow. I changed it to 50 MHz in Vivado and generated a new HDF and then a new Petalinux  project. It then worked.
    You might be able to just change it in the device tree by adding this to system-top.dts
    &sdhci0 {
    clock-frequency = <25000000>;
  • jafoste4
    0 jafoste4 over 7 years ago
    Hi Jiang,
    Can you confirm for me that the boot mode is set correctly to sd card?
    -Josh
  • mojo_jojo
    0 mojo_jojo over 7 years ago in reply to jafoste4
    Hi Josh,
    The boot mode is set correctly (switch 1=off, and 2=on).
    Hi Clem,
    I didn't modify any files. This occurred spontaneously.
  • jafoste4
    0 jafoste4 over 7 years ago in reply to mojo_jojo
    Hi Jiang,
    I am suspecting the board may have gotten damaged some how. If its still under warranty I would contact your local Avnet office whom you purchased the board from and request an RMA.
    Thx,
    Josh
