ZedBoard Hardware Design Zedboard Tutorial issues on vivado 2015.1
  • Replies 8 replies
  • Subscribers 359 subscribers
  • Views 784 views
Hello all, I'm starting to work with the ZedBoard and as i'm going through the tutorial provided with the website. I manage to fix the first errors that I faced but right now I'm stuck in exercise 4. I've followed all the steps carefully but i can't generate my bitstream. I got the following error messages:
[Common 17-55] 'set_property' expects at least one object.It
seems to me that something went wrong on my block design (you can check it here - http://postimg.org/image/5trz6zqad/). Should I get a 16 bit vector in the IRQ_F2P entrance of my ZNYQ7 PS block? Also I can't spi_0_ss_iobuf component instaciation. any chances all this could be related? I'm running vivado 2015.1 in a windows 8.1 64bits OS
    Could you be more specific as to which tutorial you are using as there are quite a few on the website. Also what version of the Vivado tools was the tutorial you are using targeted for?
    That said, a 'set-property' error could be an issue with your .xdc constraints file not matching up correctly with your design.
    -Gary
    0 Former Member over 11 years ago in reply to Former Member
    Hi Gary, thank you for your reply
    I'm trying to follow the tutorial available at
    zedboard.org/content/zynq-zedboard-vivado-workshop
    the tutorial was target for Vivado 2014.1
    There can be minor differences as you move between different versions of the Vivado tools. I would suggest working through the tutorial in the version it was targeted for, Vivado 2014.1 in this case, first.
    As mentioned above, the error you are getting seems to indicate a difference between your design and the constraints file. It is likely that either the newer version of the tools used a different naming convention or you may have made a typo error while entering your design. I notice that the output port for the axi_quad_spi IP is named 'spi_rtl' in your block diagram but the 'set_property' constraints in the tutorial are different. I would look there if you do want to attempt to use Vivado 2015.1.
    -Gary
    Found the problem by comparing the elements in my wrapper file(pastebin. com / m9kX3E4n) and made some changes at the constrains that I was entering(final version: pastebin. com / ZHRvpmZJ), manage to run the implementation without any critical errors.
    Thanks for the replys Gary
    -Joao
    Hello Joa0!
    It seems I am doing much the same thing as you!  Although I have a Rev D Zedboard.
    Anyway I can't seem to get the LD9 to light in Exercise 2.  Can you describe how you fixed this error?
    Sorry have also posted a question about this elsewhere before I noticed this post...
    0 Former Member over 10 years ago in reply to Former Member
    hey chesser, if you still struggling with it
    have a look at this
    http://zedboard.org/content/zedboard-revision-d-bug-issues-emio-related
    The issue comes up because Vivado somehow does not want to let the user type out the constraints in the XDC file.
    If you "Open Elaborated Design" in "RTL Analysis" in the flow navigator (after synthesizing your design without pin assignments), it allows you to open the IO planning layout. In this layout , you can do your pin assignments and save them. Vivado will then not give you the set_property error.
    Note, you can select the IP planning layout from the drop down layout menu on the bar below the menu bar . It will show up when you open the elaborated design.
    Hope this helps!
    Sorry for the typo in my above post, its IO planning and not IP planning
