ZedBoard Hardware Design gpio offset
  • Subscribers 359 subscribers
  • Views 1207 views
gpio offset
How do you determine the offset of the gpioxx.
#!/bin/bash
#This appears to work with fpga.bin loaded
echo "++ Exporting switches "
for i in 0 1 2 3 4 5 6 7;
do
        sw=$(($i+65));
        echo $sw > /sys/class/gpio/export;
done;
#!/bin/sh
value=0;
do
        sw=$((72-$i));
        sw_tmp=`cat /sys/class/gpio/gpio$sw/value`;
        value=$(($value*2));
        value=$(($value+$sw_tmp));
done;
printf "0x%x %d
" $value $value;
This work with the system.ucf.
NET processing_system7_0_GPIO_pin[11]tLOC = F22  | IOSTANDARD="LVCMOS25";  # "SW0"
NET processing_system7_0_GPIO_pin[12]tLOC = G22  | IOSTANDARD="LVCMOS25";  # "SW1"
NET processing_system7_0_GPIO_pin[13]tLOC = H22  | IOSTANDARD="LVCMOS25";  # "SW2"
NET processing_system7_0_GPIO_pin[14]tLOC = F21  | IOSTANDARD="LVCMOS25";  # "SW3"
NET processing_system7_0_GPIO_pin[15]tLOC = H19  | IOSTANDARD="LVCMOS25";  # "SW4"
NET processing_system7_0_GPIO_pin[16]tLOC = H18  | IOSTANDARD="LVCMOS25";  # "SW5"
NET processing_system7_0_GPIO_pin[17]tLOC = H17  | IOSTANDARD="LVCMOS25";  # "SW6"
NET processing_system7_0_GPIO_pin[18]tLOC = M15  | IOSTANDARD="LVCMOS25";  # "SW7"
NET processing_system7_0_GPIO_pin[19]tLOC = T22  | IOSTANDARD="LVCMOS33";  # "LD0"
NET processing_system7_0_GPIO_pin[20]tLOC = T21  | IOSTANDARD="LVCMOS33";  # "LD1"
NET processing_system7_0_GPIO_pin[21]tLOC = U22  | IOSTANDARD="LVCMOS33";  # "LD2"
NET processing_system7_0_GPIO_pin[22]tLOC = U21  | IOSTANDARD="LVCMOS33";  # "LD3"
NET processing_system7_0_GPIO_pin[23]tLOC = V22  | IOSTANDARD="LVCMOS33";  # "LD4"
NET processing_system7_0_GPIO_pin[24]tLOC = W22  | IOSTANDARD="LVCMOS33";  # "LD5"
NET processing_system7_0_GPIO_pin[25]tLOC = U19  | IOSTANDARD="LVCMOS33";  # "LD6"
NET processing_system7_0_GPIO_pin[26]tLOC = U14  | IOSTANDARD="LVCMOS33";  # "LD7"
I can not get the LED to work.
    Try dmesg | grep gpio, it should give you the base address of each GPIO peripheral plus the base (offset) of the register map for the individual device registers.
    -Gary
    Step 1
    uname -a
    Linux zedboard 3.12.0 #1 SMP PREEMPT Sat Mar 29t13:42:20 MDT 2014 armv7l GNU/Lin
    ux
    Step 2
    dmesg | grep gpio
    [    0.039407] zynq_gpio e000a000.gpio:tgpio att0xe000a000 mapped to 0xe080e000
    [    0.746760] input: gpio_keys.7 as /devices/gpio_keys.7/input/input0
    [   64.860929] pmodoled_gpio: module istfrom the staging directory, the quality
    is unknown, you have been warned.
    [   64.873794] pmodoled-gpio-spi [zed_oled] SPItProbing
    Step 3
    ls /sys/class/gpio
    exporttgpiochip0  unexport
    Step 4
    export_sw
    Step 5
    ls /sys/class/gpio
    exporttgpio66tgpio68tgpio70tgpio72t   unexport
    gpio65tgpio67  gpio69tgpio71  gpiochip0
    Step 6
    switches 01010101
    read_sw
    0x55 85  this works okay
    Step 7
    trying the following since the leds were after the switches.
    less export_led
    #!/bin/bash
    echo "++ Exporting leds "
    do
            led=$(($i+73));
      techo $led > /sys/class/gpio/export;
            echo out > /sys/class/gpio/gpio$led/direction;
    done;
    ++ Exporting leds
    ./export_led: line 6: echo: write error: Device or resource busy
    ./export_led: line 7: /sys/class/gpio/gpio73/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio74/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio75/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio76/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio77/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio78/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio79/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio80/direction: No such file or director
    y
    Step 8 no new gpio73-gpio80.
    ls /sys/class/gpio
    export  gpio66  gpio68  gpio70  gpio72     unexport
    gpio65  gpio67  gpio69  gpio71  gpiochip0
    Step 9 modified export_led
    #!/bin/bash
    do
            led=$(($i+57));
    done;
    ./export_led
    ++ Exporting leds
    ./export_led: line 7: /sys/class/gpio/gpio57/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio58/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio59/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio60/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio61/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio62/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio63/direction: No such file or director
    y
    ./export_led: line 7: /sys/class/gpio/gpio64/direction: No such file or director
    y
    step 10
    ls /sys/class/gpio no new gpio57-gpio64
    The initial system.bit was ZedBoard_Linux_Design.
    fpga.bin was generated with cf_adv7511_zed and uses
    less /etc/init.d/fpga-image-load.sh
    #!/bin/sh
    BITFILE=/usr/share/fpga.bin
    case "$1" in
      start)
        if [ ! -e /dev/xdevcfg ]; then
          mknod /dev/xdevcfg c 259 0
        fi
        if [ ! -e "${BITFILE}" ]; then
          echo "FPGA bitfile ${BITFILE} does not exist"
          exit 1
        fi
        cat "${BITFILE}" > /dev/xdevcfg
        result=`cat /sys/devices/amba.[0123]/f8007000.devcfg/prog_done`
        if [ $result -ne 1 ]; then
          echo "ERROR configuring FPGA, logic is not configured!"
          exit 1
        fi
    esac
    Any and all help is appreciated.
    Take a look at the Zynq Linux Speedway, Lab 3.1 and see if that is helpful. It is based on an older version of the tools/linux but may still be on target.The Implementing Linux on the Zynq 7000 SoC can be downloaded from here:
    http://www.zedboard.org/support/trainings-and-videos
    Let us know how it works.
    -Gary
    Hello All
    My problem is that I cannot get the 8 leds to work.  The 8 switches are working.
    ls /sys/class/gpio/
    export    gpiochip0  unexport
    root@zedboard:/etc/init.d# export_sw
    root@zedboard:/etc/init.d# cat /usr/bin/export_sw
    #!/bin/bash
    do
            sw=$(($i+65));
    done;
    root@zedboard:/etc/init.d# ls /sys/class/gpio/
    cat /usr/bin/read_sw
    #!/bin/sh
    value=0;
    do
            sw=$((72-$i));
    done;
    printf "0x%x %d
    " $value $value;
    setting the switches 10101010
    root@zedboard:/etc/init.d# read_sw
    0xaa 170
    I recently built a system.bit and with meta-topic a fpga.bin
    It appears that the fpga.bin is being loaded since I have a script
    ck_fpga  that I extracted from /etc/init.d/fpga-image-load.sh
    #!/bin/sh
    #extracted from /etc/init.d/fpga-image-load.sh
    #used to check if fpga.bin was loaded.
    echo $result
    root@zedboard:~# ./ck_fpga
    1
    I would think that 8 Leds would be 73-80.
    cat /usr/bin/export_led
    #!/bin/bash
    for i in 0 1 2 3 4 5 6 7 ;
    do
            led=$(($i+73));
    done;
    This gets errors.
    Could this be the problem ZedBoard_Linux_Design net processing_system7_0_GPIO<7>  LOC = T22 while the
    cf_adv7511_zed uses NET processing_system7_0_GPIO_pin[11].  I have gone over this many times but can not determine the offsets needed to get the 8 Leds to work.   Any and all help is appreciated. Thanks
    system.ucf
    # On-board LED's           #
    net processing_system7_0_GPIO<7>  LOC = T22 | IOSTANDARD = LVCMOS33;    # LD0
    net processing_system7_0_GPIO<8>  LOC = T21 | IOSTANDARD = LVCMOS33;    # LD1
    net processing_system7_0_GPIO<9>  LOC = U22 | IOSTANDARD = LVCMOS33;    # LD2
    net processing_system7_0_GPIO<10> LOC = U21 | IOSTANDARD = LVCMOS33;    # LD3
    net processing_system7_0_GPIO<11> LOC = V22 | IOSTANDARD = LVCMOS33;    # LD4
    net processing_system7_0_GPIO<12> LOC = W22 | IOSTANDARD = LVCMOS33;    # LD5
    net processing_system7_0_GPIO<13> LOC = U19 | IOSTANDARD = LVCMOS33;    # LD6
    net processing_system7_0_GPIO<14> LOC = U14 | IOSTANDARD = LVCMOS33;    # LD7
    # On-board Slide Switches  #
    net processing_system7_0_GPIO<15> LOC = F22 | IOSTANDARD = LVCMOS33;    # SW0
    net processing_system7_0_GPIO<16> LOC = G22 | IOSTANDARD = LVCMOS33;    # SW1
    net processing_system7_0_GPIO<17> LOC = H22 | IOSTANDARD = LVCMOS33;    # SW2
    net processing_system7_0_GPIO<18> LOC = F21 | IOSTANDARD = LVCMOS33;    # SW3
    net processing_system7_0_GPIO<19> LOC = H19 | IOSTANDARD = LVCMOS33;    # SW4
    net processing_system7_0_GPIO<20> LOC = H18 | IOSTANDARD = LVCMOS33;    # SW5
    net processing_system7_0_GPIO<21> LOC = H17 | IOSTANDARD = LVCMOS33;    # SW6
    net processing_system7_0_GPIO<22> LOC = M15 | IOSTANDARD = LVCMOS33;    # SW7
    GPIO
        MIO GPIO MIO
            EMIO GPIO (Width) 60
    MIO 0   GPIO gpio[0] disabled
    MIO 9   GPIO gpio[9] disabled
    MIO 10   GPIO gpio[10] disabled
    MIO 15   GPIO gpio[15] disabled
    Ports
                  Connected Port
    (IO_IF)GPIO_0 Connected to External Ports
                  External Posts::processing_system7_0_MIO
           GPIO   External Posts::processing_system7_0_GPIO IO [59:0]
           GPIO_I                                             I [59:0]
           GPIO_O                                             O [59:0]
           GPIO_T                                             O [59:0]
                                               cf_adv7511_zed
    system.ucf
    NET processing_system7_0_GPIO_pin[11]    LOC = F22  | IOSTANDARD="LVCMOS25";  # "SW0"
    NET processing_system7_0_GPIO_pin[12]    LOC = G22  | IOSTANDARD="LVCMOS25";  # "SW1"
    NET processing_system7_0_GPIO_pin[13]    LOC = H22  | IOSTANDARD="LVCMOS25";  # "SW2"
    NET processing_system7_0_GPIO_pin[14]    LOC = F21  | IOSTANDARD="LVCMOS25";  # "SW3"
    NET processing_system7_0_GPIO_pin[15]    LOC = H19  | IOSTANDARD="LVCMOS25";  # "SW4"
    NET processing_system7_0_GPIO_pin[16]    LOC = H18  | IOSTANDARD="LVCMOS25";  # "SW5"
    NET processing_system7_0_GPIO_pin[17]    LOC = H17  | IOSTANDARD="LVCMOS25";  # "SW6"
    NET processing_system7_0_GPIO_pin[18]    LOC = M15  | IOSTANDARD="LVCMOS25";  # "SW7"
    NET processing_system7_0_GPIO_pin[19]    LOC = T22  | IOSTANDARD="LVCMOS33";  # "LD0"
    NET processing_system7_0_GPIO_pin[20]    LOC = T21  | IOSTANDARD="LVCMOS33";  # "LD1"
    NET processing_system7_0_GPIO_pin[21]    LOC = U22  | IOSTANDARD="LVCMOS33";  # "LD2"
    NET processing_system7_0_GPIO_pin[22]    LOC = U21  | IOSTANDARD="LVCMOS33";  # "LD3"
    NET processing_system7_0_GPIO_pin[23]    LOC = V22  | IOSTANDARD="LVCMOS33";  # "LD4"
    NET processing_system7_0_GPIO_pin[24]    LOC = W22  | IOSTANDARD="LVCMOS33";  # "LD5"
    NET processing_system7_0_GPIO_pin[25]    LOC = U19  | IOSTANDARD="LVCMOS33";  # "LD6"
    NET processing_system7_0_GPIO_pin[26]    LOC = U14  | IOSTANDARD="LVCMOS33";  # "LD7"
    GPIO
        MIO GPIO MIO
            EMIO GPIO (Width) 32
    Ports
                  Connected Port
           GPIO   External Posts::processing_system7_0_GPIO_pin IO [31:0]
           GPIO_I                                             I [31:0]
           GPIO_O                                             O [31:0]
           GPIO_T                                             O [31:0]
    Hello All
    /usr/bin/export_sw
    #!/bin/bash
    do
            sw=$(($i+65));
    done;
    /usr/bin/read_sw
    #!/bin/sh
    value=0;
    do
            sw=$((72-$i));
    done;
    printf "0x%x %d
    " $value $value;
    echo default-on > /sys/class/leds/ld0:red/trigger
    or
    echo 0 > /sys/class/leds/ld7:red/brightness
    echo 1 > /sys/class/leds/ld7:red/brightness
    Thanks to
    Mike Looijmans
        TOPIC Embedded Systems
        Eindhovenseweg 32-C, NL-5683 KH Best
        Postbus 440, NL-5680 AK Best
        Telefoon: (+31) (0) 499 33 69 79
    He See the documentation, just google on "/sys/class/leds" for directions.also provided a site for help on leds
    meta-topic and poky also fixed sound ADAU1761
    Thanks all
