Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum how to remove applications assigned to feeds?
  • Replies 9 replies
  • Subscribers 52 subscribers
  • Views 982 views
  • azure sphere kit
  • azurespherech
  • azure sphere
  • azuresphkt
  • azure sphere starter kit
frelfrel
frelfrel over 7 years ago
azsphere feed list
Listing all feeds.
Retrieved feeds:
--> [3369f0e1-dedf-49ec-a602-2aa98669fd61] 'Retail Azure Sphere OS'
--> [82bacf85-990d-4023-91c5-c6694a9fa5b4] 'Retail Evaluation Azure Sphere OS'
--> [8c24c679-0d0b-47ec-adad-480a6acd7e0f] 'ASTestFeed03'
--> [96bb8dd0-6d04-418b-bdc7-e5b4a34df342] 'ASTestFeed0'
--> [a1463e59-fbbe-4a2c-81de-c83c91a0bae1] 'ASTestFeed100'
but how to remove applications assigned to feeds?
  • frelfrel
    frelfrel over 7 years ago in reply to clem57 +1
    So anyway - how to remove application? The other idea is to create new feed not assigned to any device (How to do it?) and move application to that feed (How to do it)?
  • danzima
    danzima over 7 years ago
    peterfenn   hi Peter, any ideas here?
  • clem57
    clem57 over 7 years ago
    To remove the applications, frelfrel try this. It may fix your problem. But, the actual feeds may be a different problem.
    Clem
  • frelfrel
    The problem is that will remove application but not deployed over the air. Or just after a moment application over the air will be deployed once again.
  • clem57
    An Issue was opened same as yours had the following reponse:
    https://github.com/MicrosoftDocs/azure-sphere-issues/issues/120#issuecomment-517121970
    Currently, there is no way to delete the feeds and cloud config once set. I suggest you, please create a feedback item on the UserVoice and upvote. All the feedback you share in these forums will be monitored and reviewed by the Microsoft engineering teams responsible for building Azure.
    So please go to UserVoice in link above and upvote and/or enter your concerns.
  • clem57
    OK frelfrel I did some reading and digging around. Once you add them to the feed, they are set permanently. If you want to add them without that attribute add this "-temporary".  It was very poorly documented!?!
  • frelfrel
  • frelfrel
    Can i set temporary flag to existing application?
  • danzima
    danzima over 7 years ago in reply to frelfrel
    peterfenn   hi Peter, any thoughts here?
  • bwilless
    bwilless over 7 years ago
    When you put the device back into prep-debug mode "azsphere device prep-debug," the device is removed from all device groups and feeds.  Actually, it's moved into a special device group that does not have any application feeds associated with it.  I don't know of a way to remove/delete existing device groups or feeds.
    Brian
