Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Azure Sphere daily sync from abroad
  • Subscribers 52 subscribers
  • Views 821 views
  • azure sphere kit
  • azurespherech
  • azure sphere
  • daily sync
  • azuresphkt
  • azure sphere starter kit
kareka
kareka over 7 years ago
Hi All,
I'm planning to travel abroad during the Phase 1, but I still want to fulfill the daily sync.
Will it cause any problem if I sync my device from another location?
Thank you for your help in advance!
Réka
  • clem57
    clem57 over 7 years ago +1
    The only change will be the IP address. If you use the same computer, the values should be saved from each sync. Just take the same device.
  • Gough Lui
    Gough Lui over 7 years ago +1
    You can sync from any location, as long as the internet connectivity is working. I have synced from two different places without problems. Just make sure you don't change any of the names, or you might…
  • clem57
    The only change will be the IP address. If you use the same computer, the values should be saved from each sync. Just take the same device.image
  • Gough Lui
    You can sync from any location, as long as the internet connectivity is working. I have synced from two different places without problems. Just make sure you don't change any of the names, or you might appear as two separate entities on the heat map.
    - Gough
  • danzima
    danzima over 7 years ago
    As others in this thread have mentioned, this is totally fine, and your sync days will count towards your total!
