Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Any information on which PMod boards are compatible with the kit?
  • Subscribers 52 subscribers
  • Views 1288 views
  • azure sphere kit
  • azurespherech
  • azure sphere
  • azuresphkt
  • azure sphere starter kit
  • pmod
digitorus
digitorus over 7 years ago
The user guide indicates that a subset of PMod boards from Digilent and other vendors are compatible with the PMod connector on the Azure Sphere kit, but it does not indicate which ones or what the criteria for compatibility are.  Does anyone have any info on this or have any PMods that they have used successfully?  Thanks!
  • Fred27
    Fred27 over 7 years ago +3 verified
    In think that in the webinar we were also told that just the USB to UART was supported. My guess is that any that use UART should be OK, but I think it should be possible to get others that use SPI to…
  • digitorus
    digitorus over 7 years ago in reply to Fred27 +1 suggested
    Thanks! It sounds like this would be a starting list of potentially-compatible PMod candidates: https://store.digilentinc.com/by-communication-protocol/uart/ I've got the OLED PMod as well, though it looks…
  • Fred27
    0 Fred27 over 7 years ago
    In think that in the webinar we were also told that just the USB to UART was supported. My guess is that any that use UART should be OK, but I think it should be possible to get others that use SPI to work if you put some effort in.
    I'll certainly be trying to get the OLED Pmod working. I'll let you know how I get on.
  • digitorus
    0 digitorus over 7 years ago in reply to Fred27
    I've got the OLED PMod as well, though it looks like the simpler option would be to use the I2C OLED connectors on the board for that.  I'll see if I can get the PModMIC3 to run on it though.
