Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Using MikroElektronika Libraries with Azure Sphere MT3620 Kit
  • Replies 9 replies
  • Answers 4 answers
  • Subscribers 54 subscribers
  • Views 1595 views
  • azure sphere kit
  • azurespherech
  • azure sphere
rsc
rsc over 7 years ago
Does anyone know how to include a MikroElectronika library package file (.mpkg) in a Visual Studio project?
I have some click boards I'd like to use in my project.
I can extract the files from the library using the MikroE Package Manager and try and add them manually I guess.
Scott
  • peterfenn
    peterfenn over 7 years ago in reply to Fred27 +4 suggested
    David [+others on this thread] Please note the following two repositories for Click board driver code already ported for use with the Avnet Azure Sphere Starter Kit Repo for click boards already supported…
  • peterfenn
    peterfenn over 7 years ago +3 suggested
    For some practical guidance on using Click boards with the Azure Sphere Starter Kit, I recommend reading the following blog article: http://avnet.me/mt3620-click -Peter
  • cswiger
    cswiger over 7 years ago +2
    I would like to use a Click board I already have, the Nano GPS https://www.mikroe.com/nano-gps-click From a little checking that should be straightforward UART on tx/rx of the socket. I tried the https…
  • Fred27
    0 Fred27 over 7 years ago
    I think that's what you'll have to do. They don't contain code that can be included directly in a Visual Studio project. It's very likely that the code will require modification anyway.
  • peterfenn
    0 peterfenn over 7 years ago in reply to Fred27
    Repo for click boards already supported:
    https://github.com/Avnet/clickmodules
    Repo for Starter Kit demo implementations:
    https://github.com/Avnet/clickboard_demos
    -Peter
  • peterfenn
    -Peter
  • Fred27
    I was thinking about devices where there wasn't already example code for the MT3620 - such as the PN7120-based NFC click. On that case the mpkg files are not much use and it seems like it would be easiest to start from sample C code for another processor.
  • rsc
    0 rsc over 7 years ago in reply to peterfenn
    Thanks Peter, but the Stepper2 click board I want to use isn't on the list.  The boards aren't too complicated, I'll post a solution as I get it working.
    Scott
  • Fred27
    0 Fred27 over 7 years ago in reply to peterfenn
    Do you take pull requests if Scott or I get more boards working?
  • james.flynn
    0 james.flynn over 7 years ago in reply to Fred27
    Yes. Just make a pull request on the repository.
  • cswiger
    0 cswiger over 7 years ago
    I tried the https://github.com/Azure/azure-sphere-samples/tree/master/Samples/UART  demo with a jumper in TX/RX of a click socket and get a loopback at 4800 baud
    no output from the actual GPS board yet. Still reading...
  • cswiger
    0 cswiger over 7 years ago in reply to cswiger
    Looks like that device comes up in hibernation state    https://origingps.com/wp-content/uploads/2018/12/Nano-Hornet-ORG1411-Datasheet-Rev-4.1.pdf
    and will need a pulse on the ON_OFF pad to start, Click Socket pin PWM GPIO0_PWM0, until a WAKEUP is detected on the AN GPIO42_ADC1 .
