Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum LEDs blinking problem
  • Subscribers 51 subscribers
  • Views 821 views
  • azurespherech
  • azure sphere
  • azure sphere mt3620 starter kit
  • azuresphkt
  • azure sphere module
dariuszapt
dariuszapt over 7 years ago
I have made a simple application based on Blink example in Visual Studio to test functions of high-level application.
Application should work as follows:
1. Turn on 1st LED
2. Wait 1 second and turn off 1st LED then wait 1 second.
3. Turn ON 2nd LED
4. Wait 1 second and turn off 2nd LED then wait 1 second.
3. Turn ON 3rd LED
5. Wait 1 second and turn off 3rd LED then wait 1 second.
6. Start from point 1.
Im using user RGB LED as indicatior. Problem is LEDs does not turn OFF in right order. 1st LED turns ON then 2nd turns ON then 1st turns OFF i belive. There should be 1 second gap of none of LEDs switched ON but there is still 1 or few ON.
My code (Pastebin): https://pastebin.com/n49qdzR3
#include <stdbool.h>
#include <errno.h>
#include <string.h>
#include <time.h>
#include <applibs/log.h>
#include <applibs/gpio.h>
int main(void)
    // This minimal Azure Sphere app repeatedly toggles GPIO 9, which is the green channel of RGB
    // LED 1 on the MT3620 RDB.
    // Use this app to test that device and SDK installation succeeded that you can build,
    // deploy, and debug an app with Visual Studio, and that you can deploy an app over the air,
    // per the instructions here: https://docs.microsoft.com/azure-sphere/quickstarts/qs-overview
    // It is NOT recommended to use this as a starting point for developing apps; instead use
    // the extensible samples here: https://github.com/Azure/azure-sphere-samples
    Log_Debug(
        "\nVisit https://github.com/Azure/azure-sphere-samples for extensible samples to use as a "
        "starting point for full applications.\n");
    int fd = GPIO_OpenAsOutput(9, GPIO_OutputMode_PushPull, GPIO_Value_High);
    if (fd < 0) {
        Log_Debug(
            "Error opening GPIO: %s (%d). Check that app_manifest.json includes the GPIO used.\n",
            strerror(errno), errno);
        return -1;
int fd2 = GPIO_OpenAsOutput(10, GPIO_OutputMode_PushPull, GPIO_Value_High);
if (fd2 < 0) {
Log_Debug(
return -1;
int fd3 = GPIO_OpenAsOutput(8, GPIO_OutputMode_PushPull, GPIO_Value_High);
if (fd3 < 0) {
Log_Debug(
return -1;
static int buttFd = -1;
GPIO_Value_Type newButtonState;
GPIO_Id GPIO12;
buttFd = GPIO_OpenAsInput(27);
    const struct timespec sleepTime = {1, 0};
typedef enum State {ONE=1,TWO,THREE,FOUR,FIVE,SIX} State;
State Machine = ONE;
    while (true) {
//int result = GPIO_GetValue(buttFd, &newButtonState);
        //nanosleep(&sleepTime, NULL);
int res;
switch (Machine)
case ONE:
GPIO_SetValue(fd, GPIO_Value_High);
Log_Debug("LED 1 switched ON\n");
Machine = TWO;
break;
case TWO:
GPIO_SetValue(fd, GPIO_Value_Low);
Log_Debug("LED 1 switched OFF\n");
Machine = THREE;
break;
case THREE:
GPIO_SetValue(fd2, GPIO_Value_High);
Log_Debug("LED 2 switched ON\n");
Machine = FOUR;
break;
case FOUR:
GPIO_SetValue(fd2, GPIO_Value_Low);
Log_Debug("LED 2 switched OFF\n");
Machine = FIVE;
break;
case FIVE:
GPIO_SetValue(fd3, GPIO_Value_High);
Log_Debug("LED 3 switched ON\n");
Machine = SIX;
case SIX:
GPIO_SetValue(fd3, GPIO_Value_Low);
Log_Debug("LED 3 switched OFF\n");
Machine = ONE;
I dont know what is the reason of this problem. Is it because GPIO_SetValue is done asynchronously or nanosleep is non blocking and is done in another thread (OS task)?
Best Regards,
Dariusz
  • javagoza
    javagoza over 7 years ago +4 verified
    See the schematics, LEDs are in negative logic, LOW - ON and HIGH - OFF https://www.element14.com/community/docs/DOC-92843/l/aes-ms-mt3620-sk-gsch2019-07-03?ICID=azuresphere-kit-datasheet-widget
  • dariuszapt
    dariuszapt over 7 years ago in reply to javagoza +1
    Thank you very much Enrique for pointing this out and for shematics. Now everything is working fine!
  • javagoza
    0 javagoza over 7 years ago
  • dariuszapt
    0 dariuszapt over 7 years ago in reply to javagoza
