Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Challange Check-In Application not detecting IP
  • Subscribers 50 subscribers
  • Views 629 views
  • azure sphere kit
  • azurespherech
  • azure sphere
  • azuresphkt
elviswolcott
elviswolcott over 7 years ago
Using the sk_server_registration utility I am getting "Device not connected", but if I run the azsphere utility to check my connection it is successful.
Will this impact my challenge status or am I OK?
C:\Users\elvis\Documents>azsphere device wifi list
Network list:
SSID                : <removed for privacy>
Configuration state : enabled
Connection state    : connected
Security state      : psk
Command completed successfully in 00:00:01.1921238.
  • javagoza
    javagoza over 7 years ago +3 suggested
    Edit the batch file: sk_check.bat and add a pause (TIMEOUT 5) before the line :checkMAC in order to let dhcp negotiation finish before wifi show-status TIMEOUT 5 :CheckMAC for /F "tokens=1,4* delims= …
  • javagoza
    0 javagoza over 7 years ago
    TIMEOUT 5
    :CheckMAC
    for /F "tokens=1,4* delims= " %%A in ('azsphere device wifi show-status') do (
  • danzima
    0 danzima over 7 years ago in reply to javagoza
    Hi Elvis, have you been using the contest server sync process? If so, are you getting confirmation emails of a successful sync? Here are details on that:
    Sensing the World Instructions for Daily Server Sync
