Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Hello! Does anyone experienced fail to find lms22hh sensor when loading examples from avnet in Microsoft Visual Studio?
  • Replies 7 replies
  • Answers 3 answers
  • Subscribers 51 subscribers
  • Views 1182 views
  • azure sphere kit
  • azurespherech
  • azure sphere
  • azuresphkt
  • azure sphere starter kit
johndoe89
johndoe89 over 7 years ago
After hours of installing/uninstalling Visual Studio 2017, Azure Sphere SDK, creating Azure acount and tenant,last night a managed to load the example from Avnet first part tutorial. But in the output window it shows me that it failed to find the lms22hh sensor. It found one sensor on the i2c.
Does anyone know if i have to decomment some instruction or change some jumper or is a problem with the board?  Has anyone experienced this? I find the usage and developement on this board very challenging and slow going due to endless documentation provided both by avnet and microsoft!
  • johndoe89
    johndoe89 over 7 years ago in reply to danzima +2 suggested
    I managed in the end, to get data from the sensor i solved by making the example 1 from avnet closelly and trying different settings in Visual Studio. There is no problem with the example although i think…
  • bwilless
    bwilless over 7 years ago in reply to johndoe89 +2 suggested
    I have a typo in my message above, and I can't edit it. So here's the correction . . . These temperature are internal to each silicon device (measuring core/die temperatures) and are NOT measuring room…
  • danzima
    danzima over 7 years ago +1
    peterfenn hi Peter, any ideas on this?
  • danzima
    0 danzima over 7 years ago
  • johndoe89
    0 johndoe89 over 7 years ago in reply to danzima
    I managed in the end, to get data from the sensor i solved by making the example 1 from avnet closelly and trying different settings in Visual Studio. There is no problem with the example although i think that the two temperature sensors must be calibrated... they show me two values different by just 2 degrees... i have to dig deeper in the code to see if that is correct!
  • clem57
    0 clem57 over 7 years ago
    johndoe89 I would suggest if this is a click board, try https://www.mikroe.com/click/sensors to pull up the specs and tutorials. It helped me to understand.image
  • johndoe89
    0 johndoe89 over 7 years ago in reply to clem57
    I have some boards from Digilent and Mikroe and i will try to integrate them into the project. I thank you for your reply and suggestions!
  • bwilless
    0 bwilless over 7 years ago
    We've seen examples where access to the slave I2C LPS22HH device fails.  Usually a power cycle of the board will clear the issue.
    Regarding the temperature sensors showing different readings.  These temperature are internal to each silicon device (measuring core temperatures) and are measuring room temperatures.
    Brian
  • johndoe89
    0 johndoe89 over 7 years ago in reply to bwilless
    Thank you for your reply! I think you are right! I will see if calibration is needed, i will try to read the datasheets when i'll have some spare time.
  • bwilless
    0 bwilless over 7 years ago in reply to johndoe89
    These temperature are internal to each silicon device (measuring core/die temperatures) and are NOT measuring room temperatures.
    Brian
