Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Can you enter both contests?
  • Replies 13 replies
  • Answers 9 answers
  • Subscribers 54 subscribers
  • Views 1760 views
elviswolcott
elviswolcott over 7 years ago
Are we allowed to enter a project into both the Hackster.io and element14 challenges/contests?
    dougw over 7 years ago +4 suggested
    You can definitely participate in both contests if you have a separate device for each contest. I don't know if it is possible with one device - you would at least need to satisfy both phase 1 synch periods…
  • danzima
    danzima over 7 years ago +3 suggested
    Hi Elvis! Douglas has it correct below: you can join both contests, but your submissions to both MUST be unique. It is a standard term of our Design Challenges that your build must be unique to that challenge…
  • danzima
    danzima over 7 years ago in reply to elviswolcott +3 suggested
    Hi Elvis, you certainly could enter with one device! But we understand if it's easier to do two builds with two kits, so if you request a second (if available) and are not abusing the system we are fine…
  • clem57
    0 clem57 over 7 years ago
    Yes as long as you follow the rules for each one. They overlap but not 100%.image
  • clem57
    0 clem57 over 7 years ago in reply to clem57
    But I see this:
    clem57  wrote:
    Register for your free kit via desktop and participate in one of two challenges: Sensing the World Challengeand Hackster.io's Secure Everything Contest.
    So maybe danzima can check this out for a definitive answer.
    0 dougw over 7 years ago
    I don't know if it is possible with one device - you would at least need to satisfy both phase 1 synch periods without overlap (ie synch for 45 days instead of 15 or 30) and create two different IoT applications for phase 2. However since one objective is to test maximum simultaneous access, and 1 device cannot look like 2 devices, it would be more compliant to have 2 devices.
  • danzima
    0 danzima over 7 years ago in reply to clem57
    Hi Clem, this wording is misleading, our fault! Can you point me in the direction of where you found that so I can make a change?
  • danzima
    Hi Elvis! Douglas has it correct below: you can join both contests, but your submissions to both MUST be unique. It is a standard term of our Design Challenges that your build must be unique to that challenge. The contest server sync process exists in both challenges, and both will require a new project build for each challenge.
  • clem57
    0 clem57 over 7 years ago in reply to danzima
    Azure Sphere Right under the Welcome to ... and above the orange  Register for free kit button
    Clem
  • danzima
    Thanks Clem, let me go correct that!
  • elviswolcott
    0 elviswolcott over 7 years ago in reply to danzima
    To clarify, we can enter both with 1 device?
  • danzima
    0 danzima over 7 years ago in reply to elviswolcott
    Hi Elvis, you certainly could enter with one device! But we understand if it's easier to do two builds with two kits, so if you request a second (if available) and are not abusing the system we are fine with a competitor in both challenges having two kits.
  • wesee
    0 wesee over 7 years ago in reply to danzima
    To clarify, we can enter both contests.  But we can not submit the same project for both.  We need to submit one project per contest.  Is that correct?
