Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum My Azure Sphere is Not Getting Power.
  • Replies 10 replies
  • Subscribers 53 subscribers
  • Views 1692 views
  • azure sphere
  • help
  • element14
  • internet of things
  • electronics
mrburnwal
mrburnwal over 7 years ago
Hello Everyone, I have ordered an Azure Sphere Starter Kit last month from element14. Today when I cloned a piece of code from Github and ran it on Visual Studio and after it was working Suddenly My Azure Sphere stopped getting power from my Laptop. I thought it can be a problem from my laptop port but after changing port and performing all the troubleshoot steps too this issues didn't resolved and i don't know what should I do next. Please help me guys. _/\_
  • clem57
    clem57 over 7 years ago +1
    Do you get any lights? Yes, maybe other issues. Otherwise you can look at CR2032 battery which can be fitted to the board to power . Read carefully: https://docs.microsoft.com/en-us/azure-sphere/hardware…
    shabaz over 7 years ago in reply to clem57 +1 suggested
    That's likely not credible - it's from a guy who thinks 20,000 of the devices are faulty. He borrowed some multimeter from a repair store. If you look at his comments, his test was: The current goes over…
  • danzima
    0 danzima over 7 years ago
    peterfenn
    bwilless
    Hi folks, any insights regarding the above issue?
  • clem57
    0 clem57 over 7 years ago
    Do you get any lights? Yes, maybe other issues. Otherwise you can  look at  CR2032 battery which can be fitted to the board to power. Read carefully:
    https://docs.microsoft.com/en-us/azure-sphere/hardware/mt3620-user-guide#power-supply
  • mrburnwal
    0 mrburnwal over 7 years ago in reply to clem57
    Thank You for your attention but I have Azure Sphere Starter Kit and you have sent documentation for another board.
  • clem57
    0 clem57 over 7 years ago in reply to mrburnwal
    That is a Microsoft reference board they use for there testing. But I believe there is still a spot for connecting a CR2032 battery.
  • mrburnwal
    Board is completely dead. No troubleshoot steps worked.
  • clem57
    Then the U5 LDO is gone.
    Update: after checking the sources, I find they were not collaborated thoroughly with hard pictures or technical details. So ignore my comments. Sorry for the confusion...
    0 shabaz over 7 years ago in reply to clem57
    Hi Clem,
    What is this based on? The only reference I can find, is that someone took the board to a repair store and they checked something with a multimeter. Is there any other reference to U5 causing the issue?
  • clem57
    0 clem57 over 7 years ago in reply to shabaz
    Well that only reference was How to replace the regulator (U5) on AVNET Azure Sphere Starter Kit!
    image Please read this with a grain of salt...
    The current goes over 5.xxx on component C8.
    For a start, it's not possible to measure current in this way on a board with a multimeter. Maybe he meant voltage. There's nothing wrong with the voltage going beyond 5.0V slightly, but it's impossible for it to exceed much beyond that (maybe 5.2V?) since the board is powered via USB. Finally, U5 is has overload protection even if current draw was high. I'm not saying it couldn't have failed, but it's impossible to assume it from that reference.
  • xeonaj
    0 xeonaj over 7 years ago in reply to clem57
    OOPS! Sorry for being bit overactive!
    In fact, me == bit tensed!
