Dev Tools
Dev Tools
Forum Reflash Xplained Evaluation Kit for ATxmega128A1 with bootloader
  • Subscribers 80 subscribers
  • Views 2064 views
geshka
geshka over 5 years ago
Hello there.
I happened to have  Xplained Evaluation Kit for ATxmega128A1 board that was previously preprogrammed with some sort of SW which caused to not being recognized with USB port.  May be boot-loader was wiped , not sure though. Is there way to reset board to initial condition ?
  • BigG
    BigG over 5 years ago in reply to geshka +1
    I merely cut that info from the user document found on Element14. Best ask directly https://www.microchip.com/
  • BigG
    0 BigG over 5 years ago
    According to the documentation...
    The boot loader on the ATxmega128A1 is evoked by pushing the mechanical switch (SW0) during reset. Programming can be performed by using the BatchISP command line tool from the FLIP installation.
    If that does not work then there's a remote possibility that it might not be the board bootloader (assuming it was not overwritten) that is causing the problem. Did you change computer, change the computer OS perhaps. It may be that your computer simply does not recognise the USB driver... but then again that's only likely if using an old Window's OS. With Linux there's no problem... according to documentation:
    When connecting the XMEGA-A1 Xplained to a PC, the operating system will request a driver file for installing the serial communication driver. This driver file is available in the zip file associated with this document. The driver file supports both 32- and 64-bit versions of WindowsRegistered XP and Windows7. Driver installs are not necessary on LinuxRegisteredoperating systems.
    If that does not help then what IDE are you using? And if using the prescribed IDE and still nothing then try using an AVR programmer.
  • geshka
    0 geshka over 5 years ago in reply to BigG
    Thanks a lot for your answer.   You mentioned "This driver file is available in the zip file associated with this document." Could you, please, point me to the link of the driver?   Much appreciated,
  • BigG
    0 BigG over 5 years ago in reply to geshka
