Dev Tools
Dev Tools
Forum Wireless relay control
  • Subscribers 81 subscribers
  • Views 949 views
  • controller
  • power_management
  • power_distribution
  • ac
  • Technology
  • tools
  • power
Catwell over 14 years ago
To be honest, I am sure something like this exists, but I am have not hat the time to search it out.
I need a way to wirelessly turn on/off relays controlling AC mains at the light switch or wall socket point.
I could also use the power wiring as part of the control, so it does not have to be RF in any way.
One more catch, I want to handle several AC spots.
All thoughts accepted.
Cabe
    You can do it with Xbee's, http://www.adafruit.com/blog/2009/04/21/using-xbees-to-control-relays/
    Or using the power wiring perhaps modulate a DTMF signal into the line and use a PIC to watch for its specific value and toggle a relay. or demod and use filters to isolate signal and trigger a relay.
  • Catwell
    0 Catwell over 14 years ago in reply to e14 Contributor
    At $10 a module, it is not that bad of a choice.
    Thanks for the response.
    Cabe
  • Catwell
    0 Catwell over 14 years ago in reply to Catwell
    On closer inspection, I would like some other ideas.
    I would like a wired option, since wireless is so susceptible to noise and obstructions. The place these relays will be placed will be very industrial.
    Thoughts?
    Cabe
  • Catwell
    I do not like bumping my own posts, but I really do need help with this project.
    Any and all suggestions will be greatly appreciated.
    Cabe
    0 e14 Contributor over 14 years ago in reply to Catwell
    Mad idea but you could do this with a handful of shift registers, in a parallel-serial-parallel formation. Would just need a handful of switches to a PISO to act as a controller (or use microcontroller?) and then pass the Data,Clk,latch as a bus to each socket in a loop. At each socket use a SIPO register with a relay attached to a different output pin for each socket. I don't know of the enviroment your putting this into but 4-core would probably make a suitable bus, just need to manage the voltage drop over distance.
