Dev Tools
Dev Tools
Forum DC motor controller needed for dental chair
  • Subscribers 81 subscribers
  • Views 661 views
  • controller
  • power_management
  • power_distribution
  • knode
  • power_supply
  • dev
  • tools
  • dc
  • power
  • motor
  • power.power
Latch
Latch over 14 years ago
I have a dental chair with a broken DC motor controller board. There are no identifying marks on the motor or the main controller board unfortunately.
The motor is connected to a large capacitor.
I want to make a circuit that will make the motor spin in both directions with a toggle switch.
Any direction you can give is appreciated.
Latch
  • YT2095
    0 YT2095 over 14 years ago
    if you don`t need things like speed control, then you could just use the DPDT toggle switch on its own.
  • Latch
    0 Latch over 14 years ago in reply to YT2095
    YT,
    Using a switch is ultimately what I will use for a toggle, but I need to wire up the motor for both directions.
    This is where I need help. I need help with some sort of control circuit.
    Latch
  • YT2095
    0 YT2095 over 14 years ago in reply to Latch
    if you get a DPDT switch (On-Off-On) and wire the 2 motor power wires to the middle pins of the switch, and then wire up + - to the top 2 pins, and then - + to the bottom 2 pins, you`ll have exactly what you need image
    in the the Middle position the motor is Off.
    in the Top position the motor gets + and - (forwards direction).
    in the Bottom position it gets wired - and + (reverse direction).
    hope that`s a little clearer, All the best and Happy New Year!
  • Latch
    That does sound easy.
    Know how to wire the capacitor with the motor?
    Latch
