Dev Tools
Dev Tools
Forum attiny84 library for arduino
  • Replies 8 replies
  • Answers 2 answers
  • Subscribers 81 subscribers
  • Views 2285 views
I want to program Attiny84 using Arduino Uno as ISP, but can not find proper library. I used to program Attiny85 using attiny45_85.zip This library does contain also Attiny84, however not to be programmed with Arduino as ISP. I found other libraries, like arduino-tiny-0100-0016.zip, but they too do not provide choice of Attiny84 to be programmed with Arduino as ISP. Can anyone help?
  • fvan
    0 fvan over 12 years ago
    you can find more recent versions of ATtiny cores on https://code.google.com/p/arduino-tiny/downloads/list
    I don't have any ATtiny84 to try it out, but the combination of ATtiny84 with Arduino as ISP is possible.
    Hope this helps,
    Frederick
    0 e14 Contributor over 12 years ago in reply to fvan
    Downloaded the newest file from the link provided (arduino-tiny-0150-0020.zip), but it still does not contain a choice on Arduino IDE at Tools-Board for Attiny84 w/Arduino as ISP. It contains only Attiny84 (internal oscilator; BOD disabled) with different MHz options. image  You don't actually have to have a chip to test that.
  • fvan
    0 fvan over 12 years ago in reply to e14 Contributor
    In Tools > Programmer, you should be able to select "Arduino as ISP" with Tools > Board > "ATtiny84 ..." selected.
    I am using Arduino 0022. It does not have Programmer option on Tools menu. Will try ver. 1.0.5.
  • fvan
    Good, let us know if it solves your issue image
    Tried ver 1.0.5. Looks like it's gonna work. But I get "Problem uploading ...". Could that be because I connect all the programming wires to the six separate ICSP pins on Uno ?
  • fvan
    On the ATtiny cores download page, there are 2 versions: one for Arduino 1.0 and one for 1.5.
    From your comments, it seems you are using the cores for Arduino 1.5 with Arduino 1.0(.5)
    * arduino-tiny-0150-0020.zip is for Arduino 1.5
    * arduino-tiny-0100-0018.zip is for Arduino 1.0
    Tried as you all advised. It seems that you can not use ICSP pins for connecting Arduino as a programmer. Connected to regular MISO, MOSI, SCK, etc pins and programming worked just fine. Thanks for your advise!
