Dev Tools
Dev Tools
Forum PiFace Shim RTC not recognised on a RPi B+
  • Replies 27 replies
  • Answers 5 answers
  • Subscribers 84 subscribers
  • Views 6184 views
  • clock
  • shim-rtc
  • rtc
  • timestamp
  • rtcc
  • realtime
  • calendar
New stock Raspberry Pi B+, new stock PiFace Shim RTC, fresh battery, all updates applied
Here's the error messages
pi@raspberrypi ~ $ hwclock
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --debug option to see the details of our search for an access method.
pi@raspberrypi ~ $ sudo hwclock
pi@raspberrypi ~ $ sudo hwclock -s
pi@raspberrypi ~ $ sudo hwclock --debug
hwclock from util-linux 2.20.1
hwclock: Open of /dev/rtc failed: No such file or directory
No usable clock interface found.
Cheers
    e14 Contributor over 11 years ago in reply to e14 Contributor +1
    Hi, seems to work now: sudo hwclock -r su 15. helmikuuta 2015 23.54.22 -0.035001 seconds In my case Raspberry's i2c did not work properly and there seems to be some problem in installation script, too…
    Jukka, I want to thank you very much for this splendid piece of work which taught me a lot. Prof. of Physics, CERN collaborator for over 50 years, I have seen very few such things. Jacques Goldberg
  • mconners
    mconners over 10 years ago in reply to mconners +1
    As promised here is my experience setting up a RTC device via I2C on a Ras Pi 2 Enabling RTC on the Raspberry Pi 2 Mike
  • amgalbu
    0 amgalbu over 11 years ago
    Hi @bandit-rider
    did you get an error when you ran the installation script install_pi_facereal_time_clock.sh?
    0 e14 Contributor over 11 years ago in reply to amgalbu
    Hello amgalbu
    I've just entered the command again and got the same result
    Though new to the Raspberry Pi, I've entered Unix/Linux commands in various flavours of Linux on both PCs and the iMac I own
    pi@raspberrypi ~ $ sudo ./install-piface-real-time-clock.sh
    Enabling I2C module.
    Changing /etc/rc.local to load time from PiFace Clock.
    Please reboot and then set your clock with:
        sudo date -s "14 JAN 2014 10:10:30"
    pi@raspberrypi ~ $
    Again any ideas to through light on what's happening would be much appreciated
    Regards
    Andrea
  • amgalbu
    0 amgalbu over 11 years ago in reply to e14 Contributor
    Is it possible I2C module is not installed?
    try to run
    lsmod
    if you see any module named i2c_*
    Eventually, run
    sudo aptget install i2ctools
    Hello amgalbu
    Here is the result of run lsmod
    pi@raspberrypi ~ $ lsmod
    Module                  Size  Used by
    ctr                     3993  1
    ccm                     8238  1
    rtc_ds1307              9868  0
    i2c_dev                 6709  0
    i2c_bcm2708             6004  0
    snd_bcm2835            21342  0
    snd_pcm                93100  1 snd_bcm2835
    snd_seq                61097  0
    snd_seq_device          7209  1 snd_seq
    snd_timer              23007  2 snd_pcm,snd_seq
    snd                    67211  5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
    arc4                    1964  2
    rt2800usb              18970  0
    rt2800lib              81833  1 rt2800usb
    rt2x00usb              12510  1 rt2800usb
    rt2x00lib              48797  3 rt2x00usb,rt2800lib,rt2800usb
    mac80211              557746  3 rt2x00lib,rt2x00usb,rt2800lib
    evdev                  11000  3
    cfg80211              472025  2 mac80211,rt2x00lib
    crc_ccitt               1612  1 rt2800lib
    rfkill                 22347  2 cfg80211
    uio_pdrv_genirq         3666  0
    uio                     9897  1 uio_pdrv_genirq
    pi@raspberrypi ~ $
    and for aptget
    pi@raspberrypi ~ $ sudo aptget install i2ctools
    sudo: aptget: command not found
    pi@raspberrypi ~ $ sudo apt-get install i2ctools
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    E: Unable to locate package i2ctools
    pi@raspberrypi ~ $ sudo apt-get install i2c-tools
    i2c-tools is already the newest version.
    0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
    pi@raspberrypi ~ $
    I’ve also swapped with another RPi B+ board as I bought two at the same time, results are the same
    Just done an update and upgrade process and found a couple of changes to the raspi-config app
    pi@raspberrypi ~ $ sudo raspi-config
    Module                  Size  Used by
    ctr                     3993  1
    ccm                     8238  1
    rtc_ds1307              9868  0
    i2c_dev                 6709  0
    snd_bcm2835            21342  0
    snd_seq                61097  0
    arc4                    1964  2
    rt2800usb              18970  0
    i2c_bcm2708             6004  0
    spi_bcm2708             6018  0
    evdev                  11000  3
    pi@raspberrypi ~ $
    though still getting the same result with sudo hwclock
    A Raspberry Pi NoIR camera was also bought, this has a blue film stuck to the front, it this intended to be removed or is it to remain in place whilst using the camera
    Regards
    Andrea
  • amgalbu
    Can you at least see the Shim RTC board by typing
    i2cdetect -y -r 1
    If not, I would check the hardware connections between the two boards...
    Hi Amgalbu
    Here's the output of i2cdetect -y -r 1
    pi@raspberrypi ~ $ i2cdetect -y -r 1
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00:          -- -- -- -- -- -- -- -- -- -- -- -- --
    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 6f
    70: -- -- -- -- -- -- -- --
    pi@raspberrypi ~ $
    Does Raspian install the RTC if present from a NOOBS installer
    Regards
    Andrea
    Got the same problem, PiFace Shim RTC + Raspbian NOOBS installation on B+. I think it worked before latest upgrades a few days ago.
    I tried to re-install according to PiFace instructions, but no-work.
    Err msgs:
    1) With hwclock --debug
    "hwclock from util-linux 2.20.1
    hwclock: Open of /dev/rtc/ failed: No file or directory exist (= or equivalent; the last sentenc in my language)
    hwclock: Cannot access the Hardware Clock via any known method."
    2) lsmod
    "i2c_dev  (size) 6709 (Used by) 0
    i2c_bcm2708 (size) 6200 (Used by) 0"
    3) sudo i2detect - y 1
    in address 60:f 6f
    Any help appreciated!
    sudo hwclock -r
    In my case Raspberry's i2c did not work properly and there seems to be some problem in installation script, too.
    I got first the i2c working this way before doing the clock adjustments into the system. It was not enough to turn i2c on with raspi-config, but I had to do this additional manual stuff.
    1) add (if they are missing) to /etc/modules
    i2c-bcm2708
    i2c-dev
    and save.
    You might have to edit /etc/modprobe.d/raspi-blacklist.conf, I did not have it, so no changes here for me (if you have it, check https://learn.adafruit.com/adafruits-raspberry-pi-lesson-4-gpio-setup/configuring-i2c).
    2) edit /boot/config.txt
    dtparam=i2c1=on (here one means B+, i.e., ver. 2 using bus 1)
    dtparam=i2c_arm=on
    save, and reboot.
    3) test that the PiFace Shim RTC is connected and found on the bus
    sudo i2cdetect -y 1 (again, 1 is the bus)
    In this case 6f is marked at 60:f meaning 0x6f. It may also show as UU at 60:f, which is ok.
    4) Loading and testing the PiFace Shim RTC module
    sudo modprobe i2c:mcp7941x
    and then with root rights (= sudo bash)
    echo mcp7941x 0x6f > /sys/class/i2c-adapter/i2c-1/new_device
    exit (= to quit root rights' shell), and try
    sudo hwclock -r
    It should show very old date on the first time, but you can fix it by writing the system time to the PiFace Shim RTC with
    sudo hwclock -w
    Thereafter the time should be right, and the clock works!
    5) make it load when booting:
    add to /etc/modules (after the line i2c-dev)
    i2c:mcp7941x
    add to /etc/rc.local (before the line exit 0)
    ( sleep 2; hwclock -s ) &
    and it should give the system a time from RTC thereafter.
    I have a Pi2 and using the fresh Raspbian image. I enabled i2c and (multiple times) ran the script.
    When I do:
         sudo i2cdetect -y 1
    I get the UU on 60:f (which I understood is ok! image )
    But when I sudo su or just su and type
        echo i2c:mcp7941x 0x6f > /sys/class/i2c-adapter/i2c-1/new_device
    I get the following error:
    bash: echo: write error: Invalid argument
    Also when I first modprobe i2c:mcp7941x
    Any idea?
    Cheers!
  • clem57
    0 clem57 over 11 years ago
    #mknod /dev/rtc c [10] [135]
    mknod: invalid major device number `[10]'
    One of the sites was suggesting the following:
    "modprobe: Can't locate module char-major-10-135
    char-major-10-135 refers to the character device, major 10, minor 135, which is /dev/rtc. It provides access to the BIOS clock, or RTC, the Real Time Clock. See /usr/src/linux/Documentation/rtc.txt for more information.
    The error is because something, most likely hwclock, is trying to use /dev/rtc but you haven't configured kernel support for it in your kernel. Either delete /dev/rtc so hwclock won't try to use it or enable RTC support in your kernel. It's located in make menuconfig under "Character devices" -> "Enhanced Real Time Clock Support"."
    Clem
