Dev Tools
Dev Tools
Forum PiFace Shim RTC not recognised on a RPi B+
  • Replies 27 replies
  • Answers 5 answers
  • Subscribers 84 subscribers
  • Views 6206 views
  • clock
  • shim-rtc
  • rtc
  • timestamp
  • rtcc
  • realtime
  • calendar
New stock Raspberry Pi B+, new stock PiFace Shim RTC, fresh battery, all updates applied
Here's the error messages
pi@raspberrypi ~ $ hwclock
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --debug option to see the details of our search for an access method.
pi@raspberrypi ~ $ sudo hwclock
pi@raspberrypi ~ $ sudo hwclock -s
pi@raspberrypi ~ $ sudo hwclock --debug
hwclock from util-linux 2.20.1
hwclock: Open of /dev/rtc failed: No such file or directory
No usable clock interface found.
Cheers
    e14 Contributor over 11 years ago in reply to e14 Contributor +1
    Hi, seems to work now: sudo hwclock -r su 15. helmikuuta 2015 23.54.22 -0.035001 seconds In my case Raspberry's i2c did not work properly and there seems to be some problem in installation script, too…
    Jukka, I want to thank you very much for this splendid piece of work which taught me a lot. Prof. of Physics, CERN collaborator for over 50 years, I have seen very few such things. Jacques Goldberg
  • mconners
    mconners over 10 years ago in reply to mconners +1
    As promised here is my experience setting up a RTC device via I2C on a Ras Pi 2 Enabling RTC on the Raspberry Pi 2 Mike
    I guess you just mixed when to use and when not to use i2c: in front of the driver name? See carefully 4) above.
    Jukka,
    Jacques Goldberg
  • piknot
    0 piknot over 10 years ago
    New to Pi and Linux so bear with me.  I followed the user manual/guide and: https://www.element14.com/community/message/138941/l/re-piface-shim-rtc-not-recognised-on-a-rpi-b#138941
    Continue to receive:
    Tried:
    Loading and testing the PiFace Shim RTC module
    sudo modprobe i2c:mcp7941x
    and then with root rights (= sudo bash)
    echo mcp7941x 0x6f > /sys/class/i2c-adapter/i2c-1/new_device
    exit (= to quit root rights' shell)
    but I get:
    bash: /sys/class/i2c-adapter/i2c-1/new_device: Permission denied
    Thank you
  • mconners
    0 mconners over 10 years ago in reply to piknot
    did you go through the steps of enabling the i2c?
    what does
    ls /sys/class/i2c-adapter/
    give you?
    Mike
  • mconners
    0 mconners over 10 years ago in reply to mconners
    also, when you do
    sudo bash
    are you presented with a prompt that looks like
    root@raspberrypi:/home/pi#
    Mike
  • clem57
    0 clem57 over 10 years ago in reply to piknot
    Try:
    sudo echo mcp7941x 0x6f > /sys/class/i2c-adapter/i2c-1/new_device
    Clem
  • mconners
    0 mconners over 10 years ago in reply to clem57
    Clem Martins wrote:
    Try:
    Clem
    I tried that the other day and got a permission denied. I just retried and got a permission denied.
    -bash: /sys/class/i2c-adapter/i2c-1/new_device: Permission denied
    BTW, I wrote a blog post on enabling a DS 1307 RTC via I2C that I will be publishing after work. I will post a link here.
    After seeing a few questions on here about it I had to try it myself to see if there were any gotchas.
    Mike
  • mconners
    Mike
  • piknot
    0 piknot over 10 years ago in reply to mconners
    I2c-1
  • piknot
    Yes
