Dev Tools
Dev Tools
Forum PiFace Shim RTC not recognised on a RPi B+
  • Replies 27 replies
  • Answers 5 answers
  • Subscribers 84 subscribers
  • Views 6195 views
  • clock
  • shim-rtc
  • rtc
  • timestamp
  • rtcc
  • realtime
  • calendar
New stock Raspberry Pi B+, new stock PiFace Shim RTC, fresh battery, all updates applied
Here's the error messages
pi@raspberrypi ~ $ hwclock
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --debug option to see the details of our search for an access method.
pi@raspberrypi ~ $ sudo hwclock
pi@raspberrypi ~ $ sudo hwclock -s
pi@raspberrypi ~ $ sudo hwclock --debug
hwclock from util-linux 2.20.1
hwclock: Open of /dev/rtc failed: No such file or directory
No usable clock interface found.
Cheers
    e14 Contributor over 11 years ago in reply to e14 Contributor +1
    Hi, seems to work now: sudo hwclock -r su 15. helmikuuta 2015 23.54.22 -0.035001 seconds In my case Raspberry's i2c did not work properly and there seems to be some problem in installation script, too…
    Jukka, I want to thank you very much for this splendid piece of work which taught me a lot. Prof. of Physics, CERN collaborator for over 50 years, I have seen very few such things. Jacques Goldberg
  • mconners
    mconners over 10 years ago in reply to mconners +1
    As promised here is my experience setting up a RTC device via I2C on a Ras Pi 2 Enabling RTC on the Raspberry Pi 2 Mike
  • mconners
    0 mconners over 10 years ago in reply to piknot
    Well, take a look at the blog post I made and make sure you have everything in place.
    A couple of things to check:
    lsmod | grep i2c
    that should return
    i2c_bcm2708
    i2c_dev
    type
    grep i2c /boot/config.txt
    that should return
    dtparam=i2c_arm=on
    make sure it doesn't have a # in front of it
    after doing
    sudo modprobe i2c:mcp7941x
    lsmod | grep i2c
    should return
    i2c:mcp7941x
    and the previous 2 entries
    If any of those do not return the proper results, then there is an issue
    Mike
  • piknot
    0 piknot over 10 years ago in reply to piknot
    This is where I'm at, it appears that the clock is recognized i2cdetect  shows 6f  at lines  60 and f.  Still trying  to figure  out if software  is configured  correctly.
    BTW thanks for your  help
  • mconners
    ok, I was just trying to get a baseline
    when you do the modprobe
    then do i2cdetect
    does it ever show UU in the 6f spot?
    Mike
  • mconners
    0 mconners over 10 years ago in reply to mconners
    also, after the modprobe, when you have determined that the module has loaded
    do
    ls /dev/rtc*
    to make sure it created the device nodes
    that should return
    /dev/rtc  /dev/rtc0
    Mike
  • mconners
    actually, I take that back, it's actually the line
    echo mcp7941x 0x6f > /sys/class/i2c-adapter/i2c-1/new_device
    that creates the device.
    Mike
  • piknot
    0 piknot over 10 years ago in reply to mconners
    Mike ...
    Not sure what I did correctly or in-correctly but I am now getting UU in line 6f (I think I may of had keyboard problems with VNC).  Now the next test for me is to get the correct time set (always fun being a NOOB).
  • clem57
    0 clem57 over 10 years ago
    Please note: must solder shim to RPi! This may not be obvious to some folks,image
