Dev Tools
Dev Tools
Forum Which Development board to buy
  • Subscribers 79 subscribers
  • Views 5383 views
  • fpga
  • fpga_development_kit
mehdimoore
mehdimoore over 4 years ago
Hi All,
I have recently joined the forum but I hope I am writing the question in right forum!
I am going to buy a Xilinx FPGA development board (SOM) but I am not sure which one. I will use the board for testing/accelerating simulations of some particular DSP algorithms. For example I have implemented a 5G compliant LDPC decoder in Verilog and I want to test it on FPGA now. My application is mostly about sending data from PC to the board, do DSP processing, and then send the results back to PC. I don't need fancy peripherals so even a working USB port is enough for my work (I don't want to spend much of money on a board with numerous peripherals that I am not going to use)
my basic requirements are:
- about 300k-500k LUTs
-  1 peripheral with PC (e.g., USB, Ethernet, etc)
Due to my budget I would like to consider the cheapest options.
Any suggestion is greatly appreciated.
Mehdi
    michaelkellett over 4 years ago +2
    Try these people: https://shop.trenz-electronic.de/en/Products/Programmable-Logic/ They have a good range of reasonably priced boards. Another angle is via Aliexpress: https://www.aliexpress.com…
    shabaz over 4 years ago +1
    Hi Mehdi, That's a lot of LUTs, it would be a high-end Zync 7000 series you'd need to target (Z-7035 or higher), if you're interested in Xilinx. I don't think any FPGA board is cheap right now though…
  • rscasny
    rscasny over 4 years ago +1
    If you are looking at cost, you may also want to check Digilent. digilent.com/.../
    0 shabaz over 4 years ago
    Hi Mehdi,
    I don't think any FPGA board is cheap right now though.
    0 michaelkellett over 4 years ago
    Try these people:
    https://www.aliexpress.com/item/1005003226113191.html?spm=a2g0o.store_pc_groupList.8148356.1.7b0279c7HHqcNr
    I've bought dev boards for smaller FPGAs (in the < £30 class) from Aliexpress woth good results
  • dychen
    0 dychen over 4 years ago
    Agreed...have a look at the Zynq line. Here they are at Farnell: https://uk.farnell.com/w/c/semiconductors-ics/microprocessors-mpu/socs-mpsocs-rfsocs/prl/results?st=zynq&gs=true
    They are mostly pretty pricey, however, as the more powerful FPGA boards are, but these are a good choice.
  • rscasny
    0 rscasny over 4 years ago
