Cypress Kits
  • Cypress Kits
Cypress Kits
Forum PSoC 4 Pioneer Kit Community Project#01 - Blinking LED
  • Replies 22 replies
  • Subscribers 28 subscribers
  • Views 4739 views
  • 100projects
cy.gul
cy.gul over 13 years ago
To kick-start our 100 Projects in 100 Days community effort around the PSoC 4 Pioneer Kit, today I'm posting a simple "Blinking LED" project.
This is a very simple project that will help you get started with your first design for the PSoC 4 Pioneer Kit.
Project Schematic:
                    Actual screenshot from PSoC Creator schematic (TopDesign.cysch)image
In this design, a PWM Component drives the Pin Component which is connected to the Blue LED on the Pioneer Kit. The PWM modulates to make the blue LED blink at regular intervals
Hardware connections on the Kit:
  • Blue LED - P0[3] (this is internally wired, no extra connections required)
Software Setup:
  • See steps #1 - #6 from the main post here
Project Files:
  • Blinking LED.cywrk.Archive01.zip
    shabaz over 13 years ago in reply to shabaz +2
    The IDE installed fine, and I was able to compile a demo program. Just in case anyone tries it with Windows 7 64-bit: For me, when I tried to compile, it said a license had expired (although I've not installed…
    shabaz over 13 years ago in reply to e14 Contributor +1
    I see! It sounds straightforward and not so scary any more :-)
  • cy.gul
    cy.gul over 12 years ago in reply to e14 Contributor
    the components in blue color are for visual reference only, intended to make it easier for someone to look at your schematic and figure out whats going on.
    these components are external to the PSoC and do not factor into the project build, merely for documentation purposes!
    e14 Contributor over 12 years ago in reply to cy.gul
    Ho great,
    Thank you. It was to my idea, but I would just be sure.
