Cypress Kits
  • Cypress Kits
Cypress Kits
Forum PSoC 4 Pioneer Kit Community Project#02 - CapSense Slider
  • Replies 23 replies
  • Subscribers 28 subscribers
  • Views 5187 views
  • 100projects
cy.gul
cy.gul over 13 years ago
On the 2nd day of our 100 Projects in 100 Days community effort, I am posting one of the PSoC 4 Pioneer Kit's bundled example projects.
This is a very simple yet effective CapSenseRegistered demo that implements a 5-segment slider, like the one available on the Pioneer kit.
Moving your finger across the capacative touch slider on the board, you will observe the multicolor LEDs gradually changing color from red to green. These LEDs are driven by the PWM Component.
Project Schematic:
                            (Actual PSoC Creator project schematic "TopDesign.cysch")
    (CapSense Component Customizer - Implementing a Capacitive Touch Slider)
Hardware Connections (all internal to the board, no external connections required):
  • 5-segment Slider - P1[1] - P1[5]
  • Green LED - P0[2]
  • Red LED - P1[6]
Software Setup:
  • See steps #1 - #6 from the main post here
  • Main.C - This example project implement simple firmware in the project's main.c as shown below (already completed in the example project). The code implmented scans the CapSense slider, then updates the PWM's PulseWidth with the slider value.
                                      ( Project firmware - main.c )
Demo Video
Project Files:
  • CapSense.cywrk.Archive01.zip
CapSense_Configuration.zip
    e14 Contributor over 13 years ago +1
    good~!
    e14 Contributor over 12 years ago in reply to cy.gul
    Any idea where that .xml file is located? I looked through the project directory and only found one, PSoCCreatorExportIDE.xml, and it doesn't appear to be tied to the CapSense.
  • cy.gul
    cy.gul over 12 years ago in reply to e14 Contributor
    William, I re-attached the CapSense configuration xml to the main post (you'll have to extract the .xml from the .zip)
    Btw, I just downloaded this project again, opened it in Creator, updated all Components to the latest version (Creator prompts you to do so), and then simply re-built and programmed the project on the kit - CapSense seems to work all fine.
    Just double-check you've done all these steps correctly.
  • kyle_lopin
    kyle_lopin over 11 years ago in reply to e14 Contributor
    I had the same problem.  I changed the "API Resolution"  in the "Widgets Config" tab of the Capsense Configuration box after i setup the linear slider and that worked for me.  The default was 100, but as the PWM goes to 255 so I was getting stuck with one light always being mostly on which gave it bright yellowish color.
