Cypress Kits
  • Cypress Kits
Cypress Kits
Forum Gameduino shield interfacing help
  • Subscribers 27 subscribers
  • Views 614 views
Hi all
Is possible help me with interfacing Gameduino shield and Psoc4 kit ?
http://excamera.com/sphinx/gameduino/
https://www.sparkfun.com/products/10593
Many thanks Kamil
    Any idea ?
    Please help me
    Many thanks
    Kamil
  • jesusantoniocar
    jesusantoniocar over 13 years ago in reply to e14 Contributor
    Hello Kamil.
    I hope you are better.
    could you speak more about your project, i  have not the Gameduino  shield, but if is possible i would like to help you.
    best regards,
    Jesus Antonio.
    e14 Contributor over 13 years ago in reply to jesusantoniocar
    Hi Kamil,
    If I know well, the gameduino is an independent graphic unit, connected to the arduino on standard SPI interface. It has its own small cpu with a forth instruction set, build all in a xilinx fpga. In point of view from programming, you can use basically 2 commands, one for write a memory byte, another to read it, with the arduino SPI lib support.
    I am very new in the Pioneer board, but it seems me, for a minimal demo you can use an SPI block to access the gameduino interface, and a program, which send a small piture,s data to the gameduino memory to display it.
    It has sound sythetisator too, it can be used as a tone generator, write the memory/registers started at 2A00 (VOICES) This is the base of the 64 voice registers.  Here are the details:
    http://excamera.com/sphinx/gameduino/hardware.html#low-level-spi-interface
    t.janos
    Hi t.janos
    Thanks info about gameduino spi :-)
    Yes gameduino is great platform for Psoc4 Pionner Kit
    Synthesizer engine is my favorite :-)
    Kamil
