Cypress Kits
  • Cypress Kits
Cypress Kits
Forum Using cy8ckit-042 as programmer for external board
  • Replies 8 replies
  • Subscribers 29 subscribers
  • Views 1628 views
dandumit
dandumit over 12 years ago
Dear All,
I would like to know if it's possible and some reference for using cy8ckit-042 as programmer for external board.
I have the development kit and I would like to program with it an external having psoc 4  board that I have made.
Kind Regards,
Daniel
  • cy.gul
    cy.gul over 12 years ago +1
    Correct, the PSoC 4 Pioneer Kit can be used to program an external PSoC 4 only (does not support PSoC 5LP or PSoC 3 at this point..) See section A4 of the kit user guide: http://www.cypress.com/?docID…
  • Kilohercas
    Kilohercas over 12 years ago
    Hi, i need same information since i will have to program few boards.
    So far i didn't spend any time for research, so last option would be desoldering original chip, and connecting wires to DATA/CLK/XRES pins.
    If some one know better way, i like to hear about it. Or when times comes do research myself image
  • dandumit
    dandumit over 12 years ago in reply to Kilohercas
    Well , after some research I have found a lead :
    http://www.cypress.com/?app=forum&id=4749&rID=79246
    section A.4 towards the end of the Pioneer Kit User Guide document - it documents what resistors you would need to short in order to use the onboard PSoC 5LP to program an external PSoC 4 (only PSoC 4 supported currently). I will keep you posted.
    DAniel
  • Kilohercas
    Kilohercas over 12 years ago in reply to dandumit
    Hm, no good, i need to program PSoC5LP image
    how can i do that ?
  • dandumit
    HAve a look on same document.CY8CKIT-042 PSoC 4 Pioneer Kit Guide
    At page 94 you will see details about programmer header of PSoC5 . However using this kit I don't think that's possible to program other PSoC5 only PSoC4 kind of devices...
  • dandumit
    dandumit over 12 years ago in reply to dandumit
    I have found two references for your purpose :
    http://www.element14.com/community/thread/25084/l/psoc-4-pioneer-kit-community-project036-what-i-can-use-the-psoc-5lp-too
    Using a PSoC 4 Pioneer Board as a programmer for PSoC 5LP - Cypress
    It seems that Pioneer kit can program only PSoC4 ...
  • cy.gul
    See section A4 of the kit user guide: http://www.cypress.com/?docID=47035
    PSoC 4/external PSoC program/debug header
    R32, R33, and R34
    Unsolder the resistors to disconnect SWD lines from the PSoC 4.
    Use J6 to connect and program an external PSoC
  • Kilohercas
    Kilohercas over 12 years ago in reply to cy.gul
    what would be cheapest option to program and debug PSoC5LP ?
    Since for my project i used PSoC5LP, but i didn't know that psoc4 dev kit can only program PSoC4. ( Well, that would be a lesson don't take things for granted )
  • hlipka
    hlipka over 12 years ago in reply to Kilohercas
    Your options are:
    • using a MiniProg3, which would be the safest solution
    • building a FX1-based programmer (or an FX2-based one)
    • roll your own solution with a MCU, based on Cypress documentation (this can then only do programming)
    If we are talking about the PSoC5 on the Pioneer kit, this one has a bootloader for programming. You could go with the 3rd solution for programming it into your PSoC though.
