Single-Board Computers
  • Single-Board Computers
Forum Error in BeagleBone Black product page - SD Card
  • Subscribers 56 subscribers
  • Views 309 views
  • jason_kridner
  • beaglebone_black
  • beagleboneblack
  • beagle_black
  • bbb
  • bb_black
  • beagleboard
  • beagle_bone_black
  • beagle_board
On this page:
http://uk.farnell.com/jsp/search/productdetail.jsp?CMP=cmwis_email&sku=2291620#
A 2GB Micro-SD card is listed as an accessory for the BeagleBone Black. This is a poor choice because it is not large enough to re-flash the OS onto the onboard EPROM. To do this you need a 4GB or larger Micro-SD card. (the image itself is 2GB and it also needs another OS and utility program to perform the operation).
    shabaz over 13 years ago
    Agree, 4GB is the minimum preferred. Also, some SIL or DIL header would be worth listing too, it is always useful. I'd quite like something like this, but I'm not sure it exists any more (probably popular in wire-wrap days):
    Basically it is a long header on both ends, but one end is several mm longer still. It is ideal for connecting up board-to-board or board-to-cable (or even cable-to-cable), while leaving a small gap on which you can hook up test probes.
    This would be useful in SIL and DIL variants (I've only ever seen it in DIL, and I'm running low. Not sure where I obtained it). The alternative is right-angle because it gives you space on the corner for probes.
