Single-Board Computers
  • Single-Board Computers
Forum About Evaluation board AD5933
  • Subscribers 58 subscribers
  • Views 535 views
Hello friends,
I need to know about the SDA and SCL pins on AD5933 as I did not find any holes or grooves to connect it to other hardware.
Please reply with detailed explanation.
Nikhil.
  • element14jamie
    element14jamie over 11 years ago
    Hello Nikhil,
    Welcome to the element14 Community, we hope you enjoy it! I will move this over to our Single-Board Computers area as it is a better fit.
    Thank you,
    Jamie
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago
    A quick Google for that part number finds this
    http://www.analog.com/static/imported-files/data_sheets/AD5933.pdf
    this clearly shows the SDA and ACL pins are pins 15 and 16 of the chip resp.
    If your talking about this Analog Devices: EVAL-AD5933EBZ Evaluation Board for the AD5933 1 MSPS 12-Bit Impedance Converter Network Analyzer
    then it is also clearly shown on page 36 (Pins 15 and 16) going to page 37 MPU pins 16 and 15 but no I/O connector
    This is all clearly shown in the documentation provided so im not sure what your looking for as I expect you have already found this as part of your initial investigation
    Please explain what you trying to do, perhaps then I can advise better
    e14 Contributor over 11 years ago in reply to Robert Peter Oakes
    Hi peter,
    Thanks for your response.
    I want to find out unknown impedance value using EVAL-AD5933EBZ board.
    But its confusing that how to measure unknown impedance of a sensor using EVAL-AD5933EBZ board.
    We have to specify the resistors or capacitor values in EVAL-AD5933EBZ board software. Then only mid-point gain is calculated and frequency sweep is enabled.
    Then how can we give resistor or capacitor values for a complex sensor ???
    In order to analyse the impedance characteristics with frequency, magnitude and phase ?
