Single-Board Computers
  • Single-Board Computers
Forum How can I build an image for the MaaxBoard myself?
  • Replies 30 replies
  • Answers 12 answers
  • Subscribers 63 subscribers
  • Views 5714 views
  • maaxboard
bryantfhayes
bryantfhayes over 6 years ago
I would like to compile my own image using Yocto, is there a guide for this?
  • gonewtinwind
    gonewtinwind over 6 years ago +2
    done! because the maaxboard modified the soc.mk file at u-boot/tools/imx-boot/iMX8M/soc.mk(yocto at imx-mkimage/imx-boot ) it can not support optee before because of no yocto project. I change back, so…
  • bryantfhayes
    bryantfhayes over 6 years ago in reply to joshb86 +1
    Joshua, Great to hear someone is in the same boat. I appreciate you letting me know that EVK conf didn’t work, as that was something I wanted to try. Please do let me know if you have any success with…
  • joshb86
    joshb86 over 6 years ago in reply to bryantfhayes +1 suggested
    First build utilizing imx8_all failed with errors relating to optee. It initially looked like there was a typo somewhere down the layer conf. It reports " Unsupported PLATFORM_FLAVOR "mx8_all " - Notice…
  • clem57
    0 clem57 over 6 years ago
    bryantfhayes  although old, this blog gives the methods of using Yocto to build a custom image:  https://boundarydevices.com/what-is-a-yocto-image-and-how-can-i-modify-it/ . Please read all parts before trying.
  • clem57
    0 clem57 over 6 years ago in reply to clem57
    If that gets difficult, this board can run Android 9 from Google...
  • clem57
    MaaXBoard supports OS include:
    1. Android 9.0
    2. Yocto:
    - U-Boot version: 2018.03
    - Kernel version: 4.14.78
    - image: Yocto sumo 2.5
    - Qt 5.10.1 Library or later
    - Customized UI
    Well I looked and I can tell you the way it was built
    https://www.yoctoproject.org/docs/2.5.1/brief-yoctoprojectqs/brief-yoctoprojectqs.html .
    The bad news is the hardware specifics are not freely available. Maybe someone here can help locate the Yocto hardware details?
  • bryantfhayes
    0 bryantfhayes over 6 years ago in reply to clem57
    Thanks for the response!
    I am familiar with building via Yocto, I guess my question is more about getting access to the Yocto Board Support Layers used to build specifically for the MaaxBoard Hardware. Are there not build instructions on how to produce an image similar to the pre-built one? Typically, I try to find a BSP layer to make sure the image is compatible with the hardware, but I haven't seen anything like that so far for this board.
  • jafoste4
    0 jafoste4 over 6 years ago in reply to bryantfhayes
    Hey Bryant,
    The BSP for the MaaXBoard can be found here MaaXBoard
    Is that what your looking for?
    -Josh
  • bryantfhayes
    0 bryantfhayes over 6 years ago in reply to jafoste4
    I've seen the kernel BSP stuff, I guess I am referring to the Layers responsible for Yocto building a root file system. In my past experience with the iMX8MQ, NXP has provided layers to build a demo image. It seems like Embest provides the kernel and uboot source, but no Yocto layers that actually use this source code. I would expect to find a linux-4.14.98.bbappend recipe file or something that builds the kernel for the target hardware.
  • bryantfhayes
    I also don't see a MACHINE conf file for the board.
  • jafoste4
    Hi Bryant,
    This documentation by NXP shows their typical process for rebuilding an image for one of their boards. Perhaps you can take this and re-purpose this to the MaaXBoard?
    https://community.nxp.com/docs/DOC-94866
    -Josh
  • james.flynn
    0 james.flynn over 6 years ago in reply to bryantfhayes
    Bryant, I am checking with Embest to get this information.  They were in the process of switching to the Debian rootfs (Buster) and I am not aware of the current status.
  • joshb86
    0 joshb86 over 6 years ago
    I'm hunting down the same trail Bryant. I can confirm that no distro or image variation built for imx8mqevk.conf will boot on the MAAXBOARD. I'm running a build for imx8_all now and will report back if I have any luck. It appears to me that there isn't a machine conf specifically supported just yet.
