Single-Board Computers
  • Single-Board Computers
Forum Maaxboard sn65dsi83 mipi dsi to lvds Converter Issue
  • Subscribers 58 subscribers
  • Views 3088 views
  • mipi
  • sn65dsi83
  • dsi
  • nwl
  • dsitolvds
  • imx8mq
  • dcss
  • screen
  • maaxboard
akoc
akoc over 5 years ago
Hello all,
     I have a 10.25 "1280 * 480 resolution screen. I want to run this screen with maaxboard, but I was not successful.
I connect the screen with sn65dsi83 which is a mipi dsi to lvds converter, I tried the kernel configurations with dcss and lcdif, I could only print the test pattern in the test mode on  screen when i use sn65dsi83 with maaxboard via i2c communication. I could not get any image in the normal mode .
I'm trying to stand up with maaxboard-dcss-mipi.dtb;
     When I use this dtb file, the system gets up properly, I see that the sn65dsi83 installation has been done properly, but I can't get any image. You can see the output of dmesg in the "maaxboard-dcss-mipi-dmesg.txt" file.
I'm trying to stand up with maaxboard-lcdif-mipi.dts;
     When I use this dtb file, the system loading is interrupted and the root file cannot jump to the system.
You can see the output of dmesg in the "maaxboard-lcdif-mipi-dmesg.txt" file.
Device                : Maaxboard imx8mq / https://www.avnet.com/wps/portal/us/products/new-product-introductions/npi/avnet-maaxboard/
Yocto version      : https://github.com/Avnet/meta-maaxboard/tree/zeus
sn65dsi83 driver : https://github.com/digi-embedded/linux/tree/v5.4/dey-3.0%2Fmaint/drivers/gpu/drm/bridge/sn65dsi83
Screen                : 10.25 '' 1280x480
I have a hard time understanding where I am having problems. I would be glad if you could help. Thanks
Files
1) maaxboard-dcss-mipi-dmesg.txt
2) maaxboard-lcdif-mipi-dmesg.txt
3) maaxboard-dcss-mipi.dts
4) maaxboard-lcdif-mipi.dts
5) maaxboard-dsi-common.dtsi
Message was edited by: ahmet koc
maaxboard-dcss-mipi-dmesg.txt.zip
maaxboard-lcdif-mipi-dmesg.txt.zip
maaxboard-lcdif-mipi.txt.zip
maaxboard-dcss-mipi.txt.zip
maaxboard-dsi-common.txt.zip
  • jafoste4
    0 jafoste4 over 5 years ago
    Hi Ahmet,
    Did you find success?
    What is your hardware connection looking like? Is your converter specific to Raspberry Pi? The MaaXBoard has a different MIPI DSI pinout compared to the Raspberry Pi.
    Check out this. https://www.element14.com/community/message/301846/l/differences-of-raspberry-and-maaxboard-mipi-dsi-port#301846
    Josh
  • akoc
    0 akoc over 5 years ago
    Thanks for your response Josh,
      Yes, there are different outputs, I was aware of this, but I could not solve the problem. Instead I used hdmi to lvds converter as a workaround.
