Single-Board Computers
  • Single-Board Computers
Forum Access my BeagleBone Black anywhere?
  • Answers 2 answers
  • Subscribers 59 subscribers
  • Views 1190 views
  • beaglebone_black
  • single-board-computers
  • bbb
I have a BBB, a battery pack, and a Ethernet connection to a router. I need to access the BBB via my VNC client, but cant seem to do that unless I have it plugged (via USB) into my laptop.
Is there a way for me to just turn the battery pack on, plug it into the router, and then have access to it anywhere?
  • amgalbu
    amgalbu over 10 years ago in reply to martinvalencia +3 suggested
    Hi Martin when you installed vnc server you opened two more ports (5800 and 5900) on your BBB, but in my opinion this does not expose your BBB to a greater risk Cheers Ambrogio
    e14 Contributor over 13 years ago in reply to e14 Contributor +2 suggested
    You will need to setup a VNC server on your BBB. opkg update opkg install x11vnc and then run the server once done so x11vnc -bg -o %HOME/.x11vnc.log.%VNCDISPLAY -auth /var/run/gdm/auth-for-gdm*/database…
    At a quick glance, it seems people have discussed this issue in the BeagleBone forum here. Not sure how closely this matches your configuration, but you could start with them to see if they got it going. Looks like someone had success in this discussion.
    To access it on network, you'll probably want to fix its IP with the router and use port forwarding through your router for external access to your IP.
    opkg update
    opkg install x11vnc
    x11vnc -bg -o %HOME/.x11vnc.log.%VNCDISPLAY -auth /var/run/gdm/auth-for-gdm*/database -display :0 -forever
    Then open up the VNC Client on your device and connect to your External IP address. If required forward the port number on your router.
  • martinvalencia
    0 martinvalencia over 10 years ago in reply to e14 Contributor
    Hello and thank you very much for the advice, I made the connection successfully, but I have a big question.
    maybe you can help me.
    This type of communication, damaged BBB board or is completely safe?
    Cheers
  • amgalbu
    0 amgalbu over 10 years ago in reply to martinvalencia
    Hi Martin
    Cheers
    Ambrogio
